LS2 or LS7 MAF sensor
Old Nov 20, 2014 | 10:36 AM
85SS/85GN's Avatar
Default LS2 or LS7 MAF sensor
Hi
I'm going to be doing a LS2 intake and can swap soon. What maf sensor should I go with. LS2 or LS7?
Old Nov 20, 2014 | 11:41 AM
lVloses's Avatar
Originally Posted by 85SS/85GN
Hi I'm going to be doing a LS2 intake and can swap soon. What mad sensor should I go with. LS2 or LS7?
Do you mean MAP or MAF? Either way I'd stick with stock on a NA motor.
Old Nov 20, 2014 | 02:43 PM
85SS/85GN's Avatar
Maf sensor
Old Nov 20, 2014 | 04:37 PM
91parkave's Avatar
Moderator
Ls7 mafs are like 30-40 bucks the honeycomb screen is also 11bucks. Then a tune and done. These have made 5-10 whp on our motors with stock throttle bodies and intake manifolds the number would only grow with mods.if you search on this ls4 forum i did a writeup on it
Old Nov 21, 2014 | 05:41 PM
fieroguru's Avatar
I ran both styles with my LS4 swap and both work well. The LS2 one is smaller, so it will have more resolution (and likely never be a restriction on the LS4), but the LS7 one works good as well.
For me I went with the LS7 one in a 4" tube. It was the same size as the LS2 TB and since I welded the LS7 MAF mount to the cold air intake tube, I got by with a single silicone coupler, so the install looks cleaner to me.
Old Nov 21, 2014 | 06:28 PM
85SS/85GN's Avatar
Do i need a screen for the ls7?
Old Nov 21, 2014 | 06:34 PM
lVloses's Avatar
The screen is to smooth out the airflow for better readings and without it you could have issues. So yes, run a screen with it.
Old Nov 22, 2014 | 08:13 PM
GXP25's Avatar
Links please.
Old Nov 23, 2014 | 10:31 AM
91parkave's Avatar
Moderator
Originally Posted by GXP25
Links please.
I linked it already on the thread i made about the MAF upgrade. Amazon and saxonpc.com have all the stuff u need
