New To Tuning - Questions and Suggestions
So I loaded the updates to the intune and installed the Diablo Tune on last night and everything went nice and smooth, no hiccups anywhere along the way.
After driving around town and a little on the highway and driving to and from work today (about 100 total miles) I am impressed with the out of the box Diablo Tune. Here are a couple of things I noticed:
I'm left feeling a little underwhelmed by the overall highway performance from a 60 roll held to the wood, the car only gets to 5,000 ish rpm before it shifts into 4th. Before the tune I could get pretty close to the redline and the car would do about 100 mph in 3rd gear. Now it shifts into 4th by about 85 to 90 mph. I noticed it shifting at around 5k rpm thru all the gears. Did the tune change the shift points of the tranny? ( I also installed the firm shift in the InTune as well)
I have searched around a bit on the LS4 boards and did not find much in the way of setting up the custom parameters. I have read a little about the throttle booster and I may trying messing with this.
What are some of the other things that you guys recommend tuning in the custom parameters on the LS4? I have not had a chance to look though all of the custom stuff yet.
Also , if I am going to change the tune on my car do I need to reinstall the stock tune before I change the tune or modify the existing diablo tune?
Thanks and looking forward to any of the info that you guys can pass along about the LS4 tuning.
Thanks,
Ryan
Also in HP Tuners you can just flash your new tune to your car so I would assume you can do the same with the Diablo programmers.
Or is the car shifting from 4th down to second and then into 3 rd???
Any clue why it is shifting at lower rpm than before the tune?
Thanks,
Ryan
no you do not have to restore original stock tune first before modifying the preset tune.. just select the preset tune you want to install, then select to Modify the tune.. make your changes you want.. then reinstall the tune...
the preset tunes do NOT change any shift points, so the tune didn't change that... shift pressure and how quick it shifts is changed.. but shift points themselves are still stock settings...
I can definitely get you more out of the tunes with a custom tune for it if you're ever interested in doing that...
With the custom tune, you'll gain even better/quicker throttle response & acceleration, stronger/harder pull, smoother & quicker power delivery throughout the rpm's, better tranny performance/shifting, etc...
I change a lot of things... a small sample of just SOME of the things are: disable the DOD/AFM, disable/reduce torque management, adjust part-throttle fueling/timing, WOT fueling/timing, knock retard settings, throttle settings, tranny torque, tranny torque management, tranny shifting settings (pressure/firmness, shift points, quickness), etc...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Hptuners is next for me i spent half that on this Diablo setup
