Optimum Catback Size
Old Apr 21, 2015 | 06:22 PM
Mike The Canadian's Avatar
Default Optimum Catback Size
Hey folks.
I'm not planning on doing a catback for at least a year (between the tune, winter tires, trans shift kit, cooler, pan with drain plug, and poly mount I'm planning on not spending a few bucks for a bit).
However, I see a lot of the kits you can buy online (ZZP & Magnaflow) utilize a 2.5" mandrel bent pipe.
I had a 2.5" on my 2001 Malibu with a 3x00 and it benefited with a 2.5" catback so I figured with a 5.3L LS4 a 3" catback makes sense.
What's generally optimal? I know the story on velocity, performance, shifting of power band etc. but does anyone have concrete results/comparisons?
I'm not sure what sound I want yet.. I've heard Corsa systems adapted to it, SLP LM2, Thrush and these are by far my favourite sounds thus far.
I was thinking of going with Dynomax VT's for performance but drone free operation... I'm not sure I've ever heard those on an LS4 though. I want a drone free setup and wonder whether Corsa/SLP/Thrush would provide that for me even with a big resonator (Corsa sounds amazing on youtube but sounds insanely loud).
Thanks in advance!
Mike
Old Apr 23, 2015 | 01:59 PM
CrimsonGXP's Avatar
Originally Posted by Mike The Canadian
Hey folks.
Thanks in advance!
Mike
I would think that for the best performance you would need a aftermarket downpipe which is the real bottleneck along with the headers. But as far as a catback on a mostly stock ls4 I would say 3 inch until it splits into 2 pipes. Then 2.5 or 2.75 after that. I believe stock is 2.5 into 2.25 so that would be a nice increase in size.
Old Apr 26, 2015 | 08:39 AM
Thanks, those were the lines I was thinking along.
Are thortley's still made? I've been thinking about it but am concerned because if had bad luck with headers being a high maintenance product in the past.
Old Apr 26, 2015 | 03:33 PM
black_betty's Avatar
you can port your factory exhaust manifolds if you don't want to dump $600+ on DT headers or $400 on the OBX versions. I would definitely do a 3" DP either catted or not. I have the ZZP and its great, just throws O2 codes unless you do a O2 extender or a custom tune. I would do it right the first time with the exhaust 3" to the split. ZZP makes a 3" catback or there is a company that will give you 3" tubing all bent for our car you just need to add a muffler and install. I have the site saved on my other comp.
Old Apr 26, 2015 | 09:33 PM
I suppose so.. my biggest thing isn't the $$ but the reliability.
Has anyone done PEM's with effective results?
I am also most certainly thinking of doing a 3" catted DP.
When you say O2 extender to you mean for the wiring harness?
I've also seen that website; mandrel exhaust systems... awesome deal!
Old Apr 26, 2015 | 11:14 PM
91parkave's Avatar
Moderator
Porting your manifolds won't do anything g worth wile imo. There sized appropriately. You could hog the rear out but in the end the merger between front and rear is still awful.
Thorley are still made obx as well.
Here are some pics of the rear manifold portion. But still worthwhile to at least get a downpipe
Old Apr 27, 2015 | 09:33 PM
Thorley's look to be of good quality. I stay they heck away from obx (and pacesetter). Had both on the Malibu and both developed leaks quickly enough to make me stay away (obx was the crossover again and again. Pacesetter y-pipe kept loosening).
Old Apr 27, 2015 | 11:09 PM
91parkave's Avatar
Moderator
Thorley have their stupid design too which obx did a carbon copy of. Only difference being they do t include bolts, o2 extention harness and are not ceramic coated. Not a big deal though. There have multiple member who have installed them with 0 issues
Old Apr 28, 2015 | 08:05 PM
Interesting notes guys.
Reading the Thorley threads there seems to be a loss in low end (which is to be expected). However, I wonder how it effects (or doesn't) around town driving and as much as anything the amazing highway drive-ability this car has with DOD off. You can accelerate and pass in 4th with ease at 1500 rpms and up which I really like.
Old May 1, 2015 | 09:19 AM
blkchevyz's Avatar
i did the 3 inch downpipe, a flowmaster bullet cat and then 3 inch to 2 2.5, flowmaster 1 chamber mufflers as well. i get a lot of complements on it but its a little loud on the inside for me lol
i actually have a bullet muffler i'm going to put in some time for a resonator to try and tone it down just a little more...
