Getting tuned on Wednesday
Old Jul 11, 2015 | 10:59 PM
08 pimpala ss's Avatar
Default Getting tuned on Wednesday
I found a extremely good tuner here in Palm Beach I talked with him and I'm thinking of going to a speed density tune so when he gets to the shop he is going to look through the tune that I have and some logs might do a pull on the dyno then we will make the decision. So if he thinks going SD will be better what will it take i just ordered a ls9 map I'll have it Tuesday what needs to be done in order to make it work?
Old Jul 11, 2015 | 11:41 PM
91parkave's Avatar
Moderator
Nothing else besides the map I'm sure he knows to put the proper offset for the map this might be the time to go with the custom os option from Hp tuners but see what he says
Old Jul 12, 2015 | 09:31 AM
That's the plan is to go custom os but I will see
Old Jul 12, 2015 | 05:27 PM
91parkave's Avatar
Moderator
the custom os is so much easier to tune, you have a strict boost enrich and airflow tables so you can easily tune all of your N/A areas and thenboost hits cheange up everything, its definatley the way to go on a turbo car
By Brett Foote | 2026-06-04 05:00:17
