Leak underneath leftside of bumper
Old Jul 17, 2015 | 02:49 AM
SuperAman's Avatar
Default Leak underneath leftside of bumper
Hey guys,
I just noticed a small leak underneath the left side of my front bumper. Not sure what it is, but there is a hole with something in there which is leaking.
I took a picture of it. Hope some of you guys can shed some light into this
Old Jul 17, 2015 | 05:38 AM
SteveCZ28's Avatar
i think thats the petcock to drain the coolant out of the radiator
Old Jul 17, 2015 | 09:10 AM
Sint3k's Avatar
Can't really tell, to me it looks like the radiator footing/bushings, so if thats the case. Possibly some type of radiator fluid. You really need to get "above" it and look for liquid track marks
Old Jul 17, 2015 | 11:09 AM
rottonj's Avatar
I agree, the petcock faces out so its probably the radiator bushings. Op was it antifreeze leaking?
Old Jul 17, 2015 | 02:32 PM
SuperAman's Avatar
I think it is anti freeze, the colour that is dripping is orange/reddish in colour
Old Jul 17, 2015 | 02:42 PM
Sint3k's Avatar
That "could" be antifreeze, it could also be transmission fluid. the return/exit lines on the transmission around the quick connects are known to leak.
If the consistency is like "water" it is likely antivreeze, if it is more like thin oil then trans fluid.
Old Jul 17, 2015 | 02:59 PM
rottonj's Avatar
Op is the leak on the drivers side or passenger side, left side could be different from where you are looking from . Sounds like antifreeze(Dex-cool). If it is the driver side check the transmission lines as Sint3k suggested also.
Old Jul 17, 2015 | 11:55 PM
SuperAman's Avatar
The leak is on The passenger side.
