hp tuners
Old Sep 6, 2015 | 06:39 PM
tim4daflow's Avatar
Default hp tuners
wanted to know which way to go on the hp tuner the standard suite or the pro version
Old Sep 6, 2015 | 07:00 PM
eaglegoat's Avatar
Go pro
Old Sep 6, 2015 | 07:14 PM
lVloses's Avatar
You can get a wideband to work on Standard but Pro is a lot less hassle and it's what I suggest.
Old Sep 6, 2015 | 07:16 PM
tim4daflow's Avatar
ok yall gonna break me!!!! what type of wideband do you need? any part numbers on compatible ones
Old Sep 6, 2015 | 07:59 PM
lVloses's Avatar
Any wideband works, just do your research. My actual sensor is the Bosch LSU 4.9 I believe and I use a PLX wideband gauge. I got it on sale last Black Friday for like $50 off.
Old Sep 6, 2015 | 08:13 PM
eaglegoat's Avatar
Use the Ballenger motorsports AFR 500. It's the best of the budget widebands.
Old Sep 6, 2015 | 10:55 PM
tim4daflow's Avatar
i guess ill go ahead and order the pro my buddy says he has a FAST wideband he not using so ill probably use his ill probably be back with tuning questions later lol thanks guys
Old Sep 8, 2015 | 11:38 PM
tim4daflow's Avatar
I order hp tuners pro my main reason for ordering was to advance my timing back to "normal" since I have 6 degrees pulled because of nitrous if I add the 6 back my car will run harder when not on the juice and I also have a timing adjuster that will pull timing when I activate the nitrous arming switch my question is how hard is it to learn hp tuners or at least just to adjust the timing while I play with it.
Old Sep 8, 2015 | 11:41 PM
superglide9375's Avatar
nice,wish i had the ***** to get hp,but would be lost lol,lew is only 75 every 6 mos so it don't hurt so much lol
Old Sep 9, 2015 | 12:03 AM
tim4daflow's Avatar
I just hope I can understand it lol never messed with tuning software before I can also use it on my truck when I learn my way around it I wonder if there is any step by step guides
Old Sep 9, 2015 | 04:52 PM
Don't know would think so but u lucky u can pick guys here brains for advic somebody could make some money setting up a class like a webinar to people used to I do a lot of webinars for my elevators inspection license only got to go to one sit down class a year now saves a lot of money
Old Sep 9, 2015 | 05:12 PM
91parkave's Avatar
Moderator
There a huge amount of writeups but my personal favorite is this
http://forum.grrrr8.net/mobiquo/mobi...%26tid%3D20813
Old Sep 10, 2015 | 05:10 PM
tim4daflow's Avatar
Thanks parkave you always got the good stuff lol hey guys my coworker has a innovate lc2 wideband he will sell me for $80 you guys think that will be good to use with hptuners
Old Sep 10, 2015 | 05:36 PM
91parkave's Avatar
Moderator
Absolutely, it's one of the only ones that can perform self calibration
Old Sep 10, 2015 | 08:20 PM
tim4daflow's Avatar
Ok cooll imma go ahead and pay him them. Hey park how to u do ur tuning do you have to unplug ur o2 sensor and screw in ur wideband? Or is ur wideband permanently fixed
Old Sep 10, 2015 | 09:53 PM
91parkave's Avatar
Moderator
I have a wideband 02 bung welded in opposite of the primary 02. I like to keep both however th lc2 should support narrowband output as well
Old Sep 10, 2015 | 10:08 PM
tim4daflow's Avatar
I dont know if ill keep it attached being that I have other gm vehicles I could use it on but do you have absolutely need the factory o2 plugged in while tuning or do you swap them out and put the factory back in after you finish
Old Sep 10, 2015 | 10:23 PM
lVloses's Avatar
I use my wideband as my narrowband as well. Fairly easy to wire it as well. Just ground the negative and put the positive in to your wideband controller's narrowband signal slot.
Old Sep 16, 2015 | 10:00 PM
tim4daflow's Avatar
I got my hp tuners pro and my wideband i been working so I just installed it on my laptop today and since I dont have my car I just connected it to my truck I guess I have to play with this some lol cuz I wouldnt know how to change anythin at the moment I tried to just change my idle on my truck up 100rpm just to see how to change something and it went on the table but my idle didnt change is there some kinda button u have to save this change first or am I not doing that part right
Old Sep 16, 2015 | 10:28 PM
91parkave's Avatar
Moderator
You gotta slow your roll first man lol. Start off by doing a read entire and saving your stock calibration. To actually make the change you have to use the write calibration only function.
