Torque Converter Allowed to slip
Old Oct 12, 2015 | 02:31 AM
Sint3k's Avatar
Default Torque Converter Allowed to slip
So, One of the reasons i got a new transmission long ago is I thought there was a slip while in 3rd and 4th gear. When giving the gas on the highway you can see the rpms rise and then "Grab" again.
Long story short after i got my TEP transmission the same occurred.
I'm merely writing this hear because someone else mentioned this on another forum and wanted to educate whoever may be confused about what is going on and how to fix it.
Long story short, the torque converter is set as low as 10% Pulse Width Modulation. For a lack of a better explanation, its at 10% clamping power. When it detects slip it slowly increases the "clamping" power until it stops. Then it slowly drops it back down to 10% allowing it to happen all over again. This is a recipe for eaten Torque converter clutches and material in the pan.
With HP Tuners or whatever software will allow you to modify the torque converter i would set the minimum to 90% and the max to 100%. The car will never use 100% unless it has an issue with slip at 90% which it should not. If it does then your clutch is on its way out anyways.
After making these adjustments you will be able to push the gas and the rpms will rise 1:1 with the speed of the vehicle, instead of acting like the TCC is not even engaged at all and allowing the rpms to jump up before the converter "grabs" again.
If you do not have a built transmission this may not be a good idea for you. Maybe start off at 50% minimum across the board.
Also another thing to note, this will cause the TCC to engage quickly. It will feel like a gear shift when engaging.
Old Oct 12, 2015 | 02:24 PM
91parkave's Avatar
Moderator
I'm still on my stock trans and converter using 100 and 90 been that way for the last 30k miles. I would highly recommend scaling your lockup/unlock speed though in realtion to tps. I feel 55mph is a little too low and can bog a little to much for my taste
Old Oct 12, 2015 | 03:09 PM
spawne32's Avatar
I have the updated TCC apply valve and 100/90 was way to harsh for the TCC engagement. I left those settings alone. My TCC apply and release settings are as follows, no issues with bogging....
Old Oct 13, 2015 | 01:42 AM
Sint3k's Avatar
I'm running 3.69 chain, my rpms are abit higher,I had no issues, I'm not a fan of the linear setup.I just like to know where it's on and off at.
Old Oct 17, 2015 | 08:17 AM
Koren's Avatar
So that's why after cruising for awhile and you try to reengage the gas it feels like a jerk with the rpms raising?
Old Oct 17, 2015 | 09:25 AM
Sint3k's Avatar
yes, thats exactly it. The torque converter slips a tad and regrabs so you get a shutter feeling when giving it gas after cruising. You could also be giving it enough gas to cause the Torque Converter to unlock entirely and then relock together. The way i have mine setup, it engages the clutch so fast and hard it feels like a gear change, which is fine with me.
Old Oct 17, 2015 | 09:37 AM
Koren's Avatar
If I let up off the gas on mine and then push down it opens up with no problem, that's odd in glad it wasn't just me. I should have my tune looked at but I went to a shop to get mine
Old Oct 17, 2015 | 01:26 PM
91parkave's Avatar
Moderator
Ask them to email you the file we will gladly loom at it for you
Old Oct 18, 2015 | 03:01 PM
Koren's Avatar
I'll call him to get it tommarrow probably or stop by, he's a pretty busy guy so I may have to bust his *****. I got the tune done here at performance by joe in St. Louis, he's pretty good at corvette and viper tunes, at the time I got it done he couldn't really be agreesive at it cause I was running cheap gas instead of premium, so my tune is built for 91+ incase I ever drive out of town
Old Oct 18, 2015 | 05:16 PM
Sint3k's Avatar
We would love to see the tune, and actually see if anything was really done.
Old Oct 19, 2015 | 11:07 AM
blkchevyz's Avatar
im going to have to look at that as well. i have a tep transmission with his transmission tune but it still feels sloppy.
Old Oct 19, 2015 | 11:32 AM
spawne32's Avatar
Define sloppy?
Old Oct 19, 2015 | 12:01 PM
Koren's Avatar
Wait you said his tune? You got a tune by joe or by tep?
Old Oct 19, 2015 | 01:32 PM
blkchevyz's Avatar
by tep.
havent really compared to stock but i dont think he does much other than adjust for the steeper gears.
Old Oct 19, 2015 | 01:48 PM
spawne32's Avatar
by tep.
What gearset you running? When I did the tune for my 3.29 gears I copied most of the settings from the Comp-G which had those gear ratios stock, including the tcc lockup settings. Obviously some adjustments were tweeked so they were more to my liking but you get the idea.
Old Oct 19, 2015 | 02:04 PM
severancej's Avatar
Another reason diablows.
You Rebuild a trans, nice new converter then the damn modified stock tune ruins it over time.. smh
I'm getting hp tuners, i bet even my silverado could benefit.
Old Oct 19, 2015 | 02:33 PM
blkchevyz's Avatar
3.29 as well
