Small clunk on acceleration
Old Nov 19, 2015 | 07:13 PM
gilroy222's Avatar
Default Small clunk on acceleration
The best way to describe it is exactly like a bad U-joint sounds on a rear drive.
Is there some sort of shaft or joints up front that get loose or develop play?
I'm not familiar with FWD
Old Nov 19, 2015 | 07:25 PM
spawne32's Avatar
ball joints, cv joints (although they typically clunk in turns) control arm bushings, sway bar end links (although these also clunk typically in turns)
Old Nov 19, 2015 | 09:43 PM
91parkave's Avatar
Moderator
Motor mounts lower
Old Nov 19, 2015 | 10:22 PM
Sint3k's Avatar
Originally Posted by 91parkave
Motor mounts lower
This x 2
Old Nov 19, 2015 | 11:06 PM
spawne32's Avatar
yes and those lol
Old Nov 21, 2015 | 09:41 AM
impala06ss's Avatar
Not to scare BUT my imp started clunking when first starting off (forward only) and slowly got worse, kinda like it wasnt in gear good but would clunk and then go. Bad torque converter for the second time, I'm on #3 transaxle. These transaxles I think are underrated for the engine hp. Hope thats not whats wrong with yours, like spawne32 said, that other stuff is usually pronounced in turns.....
Old Nov 21, 2015 | 03:40 PM
higsy's Avatar
Hopefully its something similar to mine , have a clunk under acceleration but also under breaking as well. Of course when i took it in the sound couldn't be duplicated. I haven't had much time to investigate but i believe its suspension related. Struts ? No noise when popped in neutral and reving. Have a tep rebuild so im eliminating that ( hopefully )lol.
Keep us posted.
Old Nov 25, 2015 | 04:37 PM
blueguy's Avatar
I get a clunk just once when I put it in gear and start to move forward. If I go slow, it won't clunk right away, but it will eventually happen not too shortly after taking off.
Old Nov 25, 2015 | 05:31 PM
superglide9375's Avatar
Trans mount?
Old Nov 25, 2015 | 10:28 PM
gilroy222's Avatar
Sh*t motor mounts don't sound like an easy fix.... it is definitly more pronounced while going straight and setting off, even slowly. Sometimes I get a similar noise on the turns but not always.
Would the motor mounts not make the same noise when simply revving in neutral?
Old Nov 25, 2015 | 10:37 PM
91parkave's Avatar
Moderator
There's no load on the drive train in neutral all three motor mounts can take about a hour to do with haND tools
Old Nov 25, 2015 | 10:41 PM
gilroy222's Avatar
Ok. Wouldn't happen to be any write ups or pics or anything would there?
Old Dec 3, 2015 | 04:13 PM
boneheadzz's Avatar
Hey all- Not to jump in and take over this post but I have this as well. I've been wanting to replace my mounts as well but I see no clear leader in aftermarket replacement parts for our cars.
What brand is a good one to get?
I have little time to research this and usually just buy from Rockauto or local parts stores. What is a decent mount that isn't a solid full race mount or whatever. My car is a stocker and I probably won't do much to it but a nice firm mount would be good enough for me. I want something that is going to last and not fail in the near future like the Rockauto or parts store cheapie replacement parts.
Thanks.
Mike
p.s. Are there only three mounts? I'm not 100% sure if it's 3 or 4.
Old Dec 3, 2015 | 11:19 PM
lVloses's Avatar
There's a lower front mount, a lower rear mount, and then the upper mount. The transmission shares the lower rear mount with the engine and then has a separate mount as well. As far as after markets go you can get poly all the way around. A member on here was getting the lowers custom made so you'd have to find that post. And as for the upper mount and the transmission mount the ones on ZZP and stuff work for our cars.
Old Jan 31, 2016 | 05:41 PM
m1a2d3's Avatar
i had a clunk on start it was upper motor mount very easy to change that one
Old Jan 31, 2016 | 05:47 PM
gilroy222's Avatar
Ya the upper looks easy. How would I go about doing the lower mounts? Or where are they located? Will be under there changing my oil soon so was going to wait till then before I check it out.
Old Feb 1, 2016 | 11:35 AM
BackInBlack02's Avatar
What is the mileage on the ones that feel the clunk on acceleration? mine is starting occasionally.
Old Feb 1, 2016 | 12:49 PM
u two get togetther and buya set rom zzp-upper polished or regular but u get poly bushing,that will make u want to go all poly,so u might as well start the process, i got 1" shorter on top but some of guys on here dont like them or u wont need it to be sorter if u do all new mounts,but i like it and if u going all out check out x11 nut on this site hope this helps
