Monsoon touchscreen with navigation help
Hi everyone,
I recently acquired a 2008 GP GXP.
I installed a new battery and now the clock on the screen is blank.
Before I put in the new battery the clock was fine as it showed the time on the top right of the touchscreen. I went to the time settings but cannot set the time. Any ideas?
Here is a post with the same problem you have, there is no answer here but it seems most came back on after a few days. Some had the dealer replace the unit, most likely unless you bought off a dealer and purchased a full warranty this will not apply. Could be the unit needs to have the upgraded disc installed, do a search here as that was recently discussed. Good luck.
http://chevyavalanchefanclub.com/caf...?topic=73514.0
