ls2 cam
Old Jan 13, 2016 | 03:05 PM
jholmes's Avatar
Default ls2 cam
Well about to replace my lifters on my car very soon. I was suggested to do a ls2 cam. Is there any info I need on the installation?
Old Jan 13, 2016 | 03:32 PM
spawne32's Avatar
you can use it, not sure if its a single bolt or 3 bolt you might need a conversion sprocket for it, make sure you replace the cam retainer plate at the same time. There are better cam's out there though if your buying a cam.
Old Jan 13, 2016 | 04:10 PM
lVloses's Avatar
If you're going to all that trouble I'd get Pat G to spec you out a cam. That way you get exactly what you want and you're not left disappointed.
Old Jan 13, 2016 | 04:18 PM
spawne32's Avatar
heres some results from cam motions 5.3 drop in performance cams
https://ls1tech.com/forums/dynamomet...hp-22rwtq.html
Old Jan 13, 2016 | 04:40 PM
jholmes's Avatar
Appreciate the info
Old Jan 14, 2016 | 10:37 AM
jholmes's Avatar
I kinda want the ls2 cam. I'm not looking for big gains. Just an improvement over the stock cam. I need a writeup of everything I need to do for that swap
Old Jan 14, 2016 | 11:49 AM
lVloses's Avatar
You don't have to go big, but just going with an LS2 cam seems like a lot of work for not much in gains. My 216/220 cam had better power down low than the stock cam and made a lot more power up top.
But for a parts list you can do a search and find all that's needed. Make sure you upgrade the timing chain. You'll need new lifters and trays. Various gaskets, bolts, and fluids. Plan on pulling the motor as it will be a lot easier than doing the work inside the vehicle.
Old Jan 14, 2016 | 12:14 PM
jholmes's Avatar
Makes me wanna go a different route on cam right now then. And everyone says go to Pat G tho. Is there a contact for him
Old Jan 14, 2016 | 01:10 PM
spawne32's Avatar
pm'ed you
Old Jan 14, 2016 | 07:30 PM
CrimsonGXP's Avatar
Just for reference....
LS4 cam specs
193/193 .482/.482 114 lsa
LS2 cam specs
204/211 .525/.525 117.5 lsa
Old Jan 14, 2016 | 08:28 PM
lVloses's Avatar
LS4 cam specs
LS2 cam specs
Yes, but why go to all the effort of installing a new cam to not get what you wanted when you could've spent a couple hundred more getting exactly what you want out of the vehicle. I'm not saying the LS2 won't make gains over the LS4. I'm just saying that you can get a cam spec'd to exactly what you want instead of falling short of what you expected.
Old Jan 15, 2016 | 12:10 PM
CrimsonGXP's Avatar
I know. I would do the same thing. I just put the specs there to compare the two cams just in case anyone was unclear on the specs. A custom grind or an aftermarket cam between say 212 and 224 with over .550 lift would definitely get more out of the car.
Old Jan 15, 2016 | 12:15 PM
CrimsonGXP's Avatar
http://www.ws6project.com/user_stor/...oducts_id=5109
Here is a link to a DOD delete kit for the 5.3s
