need help with p0449 code
Old Jan 18, 2016 | 10:04 AM
SteveCZ28's Avatar
Default need help with p0449 code
had a p0449 code pop up on my 06 mcss. it started out it would throw the code 5 seconds after car was remote started, and would kill car. I could get in, reset code, and it would be fine till the next remote start. then it came to the point, everytime the car was started it would throw the code. I can erase it, and it stays off until the next time car is started. where do I start with this code? I googled this, but not finding much info on it
Old Jan 18, 2016 | 10:36 AM
rottonj's Avatar
See if this post has any useful info.
http://montecarloforum.com/forum/eng...de-p0449-5592/
Old Jan 18, 2016 | 11:20 AM
Pauls325's Avatar
P0449 (EVAP) vent solonoid Control Circuit
The DTC is set when the command state of the driver and the actual do not match for more than 5 seconds. only throws the code if this malfunction happens two ignition cycles in a row. it will automatically turn off after 3 ignition cycles when malfunction is not detected.
try replacing evap canister.
hope this helps if not post again
Old Jan 18, 2016 | 12:13 PM
SteveCZ28's Avatar
Is the evap canister the one near the intake, or the one near the gas tank?
Old Jan 18, 2016 | 12:42 PM
Pauls325's Avatar
i can check but pretty sure its the one on the intake.
Old Jan 18, 2016 | 02:34 PM
rottonj's Avatar
Not sure , but this might be it. Do some research before buying just incase.
Amazon.com: ACDelco 214-3218 GM Original Equipment Vapor Canister Vent Solenoid: Automotive Amazon.com: ACDelco 214-3218 GM Original Equipment Vapor Canister Vent Solenoid: Automotive
Old Jan 26, 2016 | 01:10 AM
SteveCZ28's Avatar
i put a new battery in my car over the weekend. and now the code has went pending. which i read, itll remain pending for 40 starts. if after 40 starts it doesnt go active, itll get ride of the code. but i drove the car over the weekend, and didnt have the cel come back on. but im not holding my breath
Old Jan 30, 2016 | 03:21 AM
SteveCZ28's Avatar
code came back again tonite...ill try to get the canister, and try that....
on another note, ive had the canisters act up on my tahoe, but it had issues letting me pump fuel into the tank. i dont have that issue with my monte..
Old Jan 30, 2016 | 06:55 AM
rottonj's Avatar
This coincides with the smell/cat you are having? Seems possible they could be related. I wouldn't drive it until its resolved
Old Jan 30, 2016 | 08:41 PM
SteveCZ28's Avatar
the car is parked till i figure out exactly whats up with it.
i bought the canister vent solenoid for this. waiting for it to show up in the mail.
you really think this and the cat problems are related? this code started about 2.5 weeks ago. what could it do to the cat though?
Old Jan 30, 2016 | 10:22 PM
rottonj's Avatar
I don't know its related, but I don't really believe in coincidence. Usually one problem unfixed or unnoticed leads to other problems. Not sure if the vent not working could be causing the converter to overheat, just throwing **** to the wall here. Hopefully someone with more insite to these codes or problems will chime in. Good luck. Post back with your progress.
Old Jan 31, 2016 | 09:10 PM
SteveCZ28's Avatar
i would think if the vent isnt working, it would cause my fuel pump to work harder, due to possible vacuum in th tank, which may cause it to run lean( and possibly cooking the cat). and on that thought i would get codes for running lean on banks 1 and 2( i am just rambling here). but literally the only code is this current p0449. i checked before i left work the nite i drove it, and when i got home. so i dont think they could be tied together. but what do i know, i dont have a engineering degree. lol
Old Feb 1, 2016 | 12:52 PM
superglide9375's Avatar
needs a gopod free flowing cat anywa-so start there,i got magnaflow one for like 99 bucks on ebay
Old Feb 1, 2016 | 08:14 PM
SteveCZ28's Avatar
I was thinking about getting a zzp catted down pipe. But am open to suggestions
Old Feb 1, 2016 | 08:17 PM
yea good choice i got that and am extremely happy
Old Feb 1, 2016 | 08:24 PM
SteveCZ28's Avatar
On topic with this thread, my vent solenoid showed up today. But we're expecting a blizzard here in Iowa starting early in the morning till Wednesday afternoon. So it'll be a while till I get to it
Old Mar 7, 2016 | 08:25 PM
SteveCZ28's Avatar
thought id update this, incase anyone else has this code. I replaced the canister vent solenoid ( the one near the gas tank filler neck). cleared the code. and it seems to have fixed the problem. I don't have an active, or pending code for this anymore. thanks again everyone that helped
Old Mar 7, 2016 | 08:46 PM
rottonj's Avatar
Good deal.
Old Mar 8, 2016 | 11:04 AM
sweet
Old Mar 8, 2016 | 08:32 PM
SteveCZ28's Avatar
well I spoke too soon. same code came back on my way to work tonite...now where do I go to solve this?
