How to add second iat
Old Jan 20, 2016 | 08:55 PM
08 pimpala ss's Avatar
Default How to add second iat
Could someone post where I need to pin the ecu for second iat
Old Jan 22, 2016 | 09:56 PM
Thanks for the input
Old Jan 22, 2016 | 10:16 PM
spawne32's Avatar
lol i tried to locate ecu pinouts for the LSA or LS9 but came up short, i dont have access to service manuals either.
Old Jan 22, 2016 | 10:36 PM
91parkave's Avatar
Moderator
Old Jan 22, 2016 | 11:53 PM
Ok sweet I'm going to get that done now how do I turn it on?
Old Jan 23, 2016 | 12:50 AM
91parkave's Avatar
Moderator
I'll have to take a loom at my laptop later and play around
Old Jan 23, 2016 | 01:37 AM
spawne32's Avatar
thats a good question, your not fitted with a SC, your turbo, so you just want the IAT2 to read. The parameters for the IAT2 are already programmed in, not sure that it has to be "turned on" necessarily, just that the ECU really wont use it for anything.
You maybe able to use the SC "fitted" to activate the IAT2 torque management settings and then program just to use spark cut based on IAT2 readings. Enabling the DTC's for IAT Sensor 2 may also help you out.
Old Jan 23, 2016 | 02:08 AM
91parkave's Avatar
Moderator
Also check under os and engine diag to verify.
Old Jan 24, 2016 | 06:41 PM
Thanks a bunch everyone
