Moog Craplinks
Old Feb 23, 2016 | 11:45 AM
Sint3k's Avatar
Default Moog Craplinks
I recently redid all my front suspention with, "New Control Arms, New Inner Outer Tierod, sway bar bushings + End Link" This was about a year ago, 4,000 miles ago.
I was driving down a straight road going about 30 miles an hour and hit a little bump I've hit a million times, and i felt a thunk, then some clanking. I had my windows down so I could hear bolts ratteling around behind me. I looked in my rear view mirror and did infact see a bolt bouncing around. I immediately did a uturn to drive past it and once I saw it I immediately recognized it as my swaybar link, "Cause of the unique white bushings". I got to the house, jacked it up only to find out that BOTH links where broken.
Old Feb 23, 2016 | 12:43 PM
91parkave's Avatar
Moderator
That's cause you need to shorten your endlinks especially since you lowered your car, your sway bar angle and subsequent stress on the endlinks are killing them. Use a grade 8 bolt and universal poly from autozone. With supplied washers you'll be happy
Old Feb 27, 2016 | 08:30 AM
rottonj's Avatar
Those Moog are the problem solver end links so they should be under warranty..
