Decrease in mpg?
As for a smaller converter on a ls4 car I've never seen a dual bolt pattern flex plate available . Highly doubt the shop would even touch the flex plate to redrill it but stranger things have happened
It's a strainer assembly, not a pre filter, post filter, or whatever you want to name it. Just because it does something called "filtering" doesn't mean that it is serviceable or performs the same function as a "fuel filter" that we are traditionally used to. The overwhelming majority of car's since the mid 2000s have been factory equipped with this stuff and serviceable filters have gone the way of the dinosaur. Telling the OP to pull his fuel pump assembly to replace a non serviceable filter is asinine and he is going to wind up having to replace the entire pump and float assembly. I did read somewhere that if you had your pressure lines adjusted during a tune prior to a rebuild, then you should have the car retuned. My pressures were adjusted to help with shifting prior to the rebuild and with the rebuild they added a shift kit to help the shifting, if I remember correctly it was the transgo kit, not a racing one but one to help the shift patterns, which my tune also had adjusted prior to the rebuild. the builder stated he added in extra plates and new clutches etc..I have audio of what he added at home if i find anything else ill post it.
Edit ; also checked the fluid, level good and purely pink, no signs of overheat at all
Here's my question, how does the smaller converter not have enough clutch material for the LS4? Many 3800s are making good power on a 245mm. As well as physically speaking it was the same dimensions on the outside as the PI converter. Not sure how it was internally though. I'm only ~8 months in on this converter but have 0 issues with it so far and I'm not the easiest on it.
As far as the flywheel goes, intense was selling a dual bolt pattern converter for the wbody's for quite a while now. However you are right its as simple as just having it redrilled.
