Big 3/4 Wiring Upgrade - LS4
Old Mar 21, 2017 | 07:39 PM
Koren's Avatar
Originally Posted by Red_Zone
Just wondering if someone might be able to shed some light on a question I had in an earlier post in this thread... I'll cut and paste the text....
can someone explain the battery current sensor here?
Mine has 2 NEGATIVE cables running through it(and thin sensor wire)
In the pictures in this thread I see 1 - and 1 + cable running through it.
Does it not matter what runs through it?
Why do I have two negative cables yet Sint3k has a ground and positive?
IS it not supposed to work one way? Do I need two cables?
confused how this sensor is SUPPOSED to be hooked up...
all of the gxps I saw had the negative wire running through it, idk if it matters as long as it's sensing the current.
Old Mar 21, 2017 | 11:07 PM
rottonj's Avatar
The sensor on my 08 GXP is original, and has one thick and one thin cable running thru it. As ParkAve said, just go by how yours looks.
