intense racing motor mount install question
Old Jan 27, 2017 | 07:54 PM
SuperAman's Avatar
Default intense racing motor mount install question
damn this freaking mount is hard to install.
I have it halfway in and i can't get it in anymore. the guys that have used this, how did you do it?
freaking jabbed myself with a bloody screwdriver and now my hands bleeding.
any advise
Old Jan 27, 2017 | 08:05 PM
91parkave's Avatar
Moderator
Take it out grease it heavily put in vice beat it in make sure it's oriented right
Old Jan 27, 2017 | 08:10 PM
SuperAman's Avatar
damn i used a whole can of wd-40..
it those 2 side things that is making it difficult
Old Jan 27, 2017 | 08:12 PM
SuperAman's Avatar
gonna try again. good thing i bought an extra oem one in case i have trouble putting this in, so i can still drive it
Old Jan 28, 2017 | 10:04 PM
Red_Zone's Avatar
HAHA...
I remember I posted to the forum too... I think the gmls4 forum can't remember... but my post was just like yours without the bleeding... a general post to state my frustration.
It was a bitch to get in and when I finally did it I felt more satisfaction than I did when I graduated high school.
make sure the mount is warm it might make a difference not sure how cold it is where you are installing it.
But if you are not using a vice(as 91 pointed out) you have a better chance of surviving a head first 10 story fall onto concrete.
Old Jan 30, 2017 | 02:17 AM
SuperAman's Avatar
i freaking gave up for now. Luckily I anticipated something like this so I bought a new OEM one and it is on right now. Will try again the next few days, when my palm heals up a bit.
The vice grip I used made so many marks on the metal which also pissed me off
Old Jan 30, 2017 | 05:31 AM
91parkave's Avatar
Moderator
you can always take it to the shop and have someone press it in
Old Jan 30, 2017 | 08:48 AM
rottonj's Avatar
I did not use that one as I thought the same thing would happen installing.Cut it in half, right down the middle with a sawzall after removing the metal insert for the bolt. That's the way the ZZP mount is, 2 pieces.
Old Jan 31, 2017 | 05:49 PM
Red_Zone's Avatar
I believe I had to sand the inside of the metal bracket too because it had some rust... made the surface smoother.
I did not use vice grips though I used only a vice and wd40
Old Feb 1, 2017 | 10:50 AM
rottonj's Avatar
I would be using a moly grease over WD40 , couple smacks and it should go in.
Old Feb 5, 2017 | 04:54 PM
vroom_vroom's Avatar
The zzp was the way to go........
