wheel speed sensor wire
Old Jan 31, 2017 | 11:39 PM
sidmcnulty's Avatar
Default wheel speed sensor wire
anyone have any common places where my wheel speed sensor wire might be broken front right on 06 impala ss wheel bearing ohms out perfect (only couple months old) just asking if there is a common place where one may corrode off or break, thanks for your info in advance it could save me alot of time chasing it down
Old Feb 1, 2017 | 12:07 AM
Red_Zone's Avatar
commonly ABS wires have the highest probability of deteriorating closest to the sensor and as you move away from the sensor it is less common to find problems.
I believe the abs wires are usually covered in split loom all the way from the lower control arm to where they connect to the main wire harness, so inspecting the actual wire could prove tedious.
I would start with a visual inspection of the split loom itself looking for places where the loom may be damaged and go from there.
