235/249 lift on ls4?
http://www.compperformancegroupstore...ory_Code=ThKHR
If you do the DoD delete and 3 bolt cam gear sprocket conversion, also different intake? then you can run any cam made for a Ls1, Ls2, Ls6 which would make your options unlimited.
.482 / .490 cheapest bang for the buck is comp cams roller rockers sku # 19025-16 $471.12 for the set. They are 1.82:1 @ tickperformance. Effectively bringing valve opening to .542 /.550. Valves will hit the pistons at .600. Holley tall valve covers are needed for clearance pn 241-111 $219.95 / pair with hardware. Also a nice hard set of pushrods from summits pn1457325 $ 104.97 / set. Save your money and don't do an intake / throttle body mod unless you plan on turning crazy rpms.
Also with the MAS , just cut away the webing with a razor blade being careful not to touch or Nick the sensor wires. Your car will be drivable to the dyno / tuner but will run like crap on the way.also our factory injectors have a wide flow range so just to give ya stuff to think about. Hope this helps.
