A/C off to Protect Engine . . .
Old Jul 18, 2017 | 01:46 PM
SoonerAviator's Avatar
Default A/C off to Protect Engine . . .
I've got a warning telling me that the "A/C off to protect engine", while the engine temp gauge has gone dead (showing no temp at all, but does do the check-sweep on initial power-up). I have replaced the temp sensor AND the harness connector with new units, but no change. I disconnected the battery to let it reset, but I doubt that solves it. Any suggestions as to another place to look? I haven't pulled out the multimeter yet, but I wouldn't even know where to start testing, aside from continuity of the wires themselves.
Any other causes of that error message AND a dead temp gauge reading?
Old Jul 18, 2017 | 08:05 PM
Well, upon reconnecting the battery, the temp gauge is now active and error message is gone. I haven't given it a test drive, but A/C was working fine at idle. Hopefully it's not a fluke.
Old Jul 19, 2017 | 03:04 AM
klinznilk's Avatar
MY friends car did that when her thermostat had failed. We replaced the thermostat and problem went away. I am assuming this was more temp related and not the actual thermostat as I am not aware the car can monitor that part itself?
Old Jul 19, 2017 | 11:29 AM
Yes, this was a failure of the sensor and/or the associated wiring. Upon driving the vehicle this morning approximately 15 miles, temperature needle held steady at mid-range on the gauge. I believe the PCM/BCM uses the coolant temp sensor for the sole source for temp gauge output and controlling engine parameters. If this had been a stuck thermostat, the gauge should have still been operational I'd think, but reading extremely hot as the coolant wouldn't be circulating through the radiator.
Old Jul 21, 2017 | 07:41 PM
impala06ss's Avatar
That would be correct, my imp ran hot to the point the engine cooling on/off cylinder program went into effect and the gauge didn't lie. My engine ran out of coolant and I drove another 25 miles (I was unaware the lower coolant hose blew off). These are tough engines, that happened at around 75k miles and I got 312k before I parked it.
Old Jul 21, 2017 | 08:11 PM
im-not-guilty's Avatar
Check it for codes that's a fail safe for a p0128 code
P0128 98% of the time is set due to a faulty t-stat. 1% temp sensor 1% set by other
Old Jul 25, 2017 | 10:35 AM
After replacing the temp sensor, the GXP has been running perfectly for almost two weeks now. No reason to suspect issues with the T-Stat, it was just a failed sensor/wiring.
Old Jul 25, 2017 | 09:05 PM
Great to hear it's fixed man
