4T65e Trans-go Kit
Any fix for the 2-3 hard shift? or is this just the wear on the transmission?
Also, to take the transmission out the bottom, what can be used to hold the engine on top? I've seen a bar on youtube but not sure what that is or where to get it. Can a floor jack cross beam be used for this if the pads are placed at top of struts?
https://www.harborfreight.com/1000-l...bar-96524.html
Try some Seafoam trans tune and see if that helps any, for sue it wont hurt anything.
I added the Lucas transmission additive, the bottle says sometime it may take two bottles to see results.
Either way, I'm starting to save up for a TEP rebuild.
http://shop.tripleedgeperformance.co...Bar-AP5820.htm
This post has a better pic of what works.
https://ls1tech.com/forums/ls4-perfo...n-rebuild.html
