Drag Radials for Impala/Monte Wheels
Curious what brand & size of racing compound tires you guys are using on these stock wheels? I understand I'd ideally go to a wider wheel, but I'm not wanting to do that right now. I just want to get some much stickier tires on the current wheels to get her back on the road.
I run NT05R on my vette and love them, but they don't make anything small enough for these wheels. Looks like Toyo has a lot of options for size in their r888r, but I havent seen anyone locally run them yet.
The main purpose of my monte is for straight line, I don't care how long the tires last (within reason, I'm not street driving slicks), and the car won't be driven in the rain.
I know there are some high power LS4s on here, I was curious what you are running for race tires on your stock wheels.
But without knowing anything about your mods(your post says and LS4 1996 Monte but your about me says you run an L67 so... ) and not sure if you are trying to improve track times or just street driving you didn't specify... try...
1) lowering springs in the front
2) 17" or even 16" rims in the front
3) 18's in the back with a higher profile tire
4) stock springs in the back I guess
5) poly mounts if possible
6) maybe try spring blocks in the rear
7) remove your back seats
8) run a nearly empty gas tank
that sort of thing.
I find good success myself hooking up when I floor the car already doing... mmmm... I dunno... about 140 km/h... I hook up good then I suppose.
I know the tires must be replaced to have any chance of putting down power, so that's why I was hoping some of the higher power (maybe turbo) ls4 cars with these wheels could share what tire they're running.
2) 17" or even 16" rims in the front. I'm not changing wheels at this time. I intend to run these 18"s as my normal street setup in the short term.
3) 18's in the back with a higher profile tire. I'm not really planning to mess with the back tires yet. Once I get a tire to work well up front, then I'll worry about the back tires. I'm just concerned I may need to go to a wider wheel and don't want to waste money on 4 tires just to have to toss them.
4) stock springs in the back I guess. Not an option anymore as I've got coilovers all around. I've already cut off the spring perches.
5) poly mounts if possible. The uppers are all poly, the lowers are all solid rubber.
6) maybe try spring blocks in the rear. I haven't tried that yet, but I have considered swapping try a stiffer rear spring to reduce weight transfer. Once I get a reasonable tire up front, then I could try messing with it.
7) remove your back seats. I don't plan to gut it as its not a drag car.
8) run a nearly empty gas tank. Not much I can do for a street car, especially on e85, lol
It looks like itll have to be the r888r or the nt01 on these 18"s. I'll have to go down in profile from a 50 to a 40 series, but I'm not real worried about that.
How about width, anyone go with a 245 or 255 on that rim?
I think I'll give one of these two a try in the short term with the long term plan to get a wider wheel that can handle a 275 as that opens up the tire options conisderably.
