New guy with an LS4 swap project
I presume you've looked into swapping to an LS6 intake and a different throttle body to compliment your cam swap?
What are you doing for transmission mounts? Is the Z34 cradle aluminum as well like the other gens? My ls4 and 3800 cradles have different locations for the steering rack and figured it was mandatory to start with the ls4 one, would be great news if I didnt.
I am in between a 282 (only thing I can find with a donor car for peddle box/shifter plus lots of fiero replacement parts) or a 4t80 swap, the F40 doesn't look very attractive to me as the price has gotten insane on them over the years.
My cam/exhaust choice so far from research is going to be a comp cam thumpr cam(the sound I'm going for, idc about performance/gm asa cam is close second), ebay headers, and a cutout to a side boom tube with oval tubing. I'm also leaning towards a Volvo electric steering pump to clean up the pulley system and fit a 92mm intake on it and MAYBE running an external davies electric water pump to get rid of the rest of the accessories leaving only the ac and alternator.
In regards to the steering rack, I read somewhere that the mounting is the same (two bolts of course), but if it's not, I'll just reuse the MC rack, and bolt the LS4 lines up to it, since they're in virtually the same location on the rack.
If you do go the route of the manual, the 284 is the best candidate for the W-body (your Monte Carlo) as despite it's paltry rating, its been proven to handle nearly triple of its rated power level capacity. If you decide on the 282, it'll work, but may not survive the power of the LS4. The pedal boxes are the same between the 282 and 284 cars, though you can get by with just adding a clutch pedal to your current pedal box by making a mount for it.
I unfortunately have no inputs to the cam and exhaust choices as this will be my first foray into modding LS motors to this degree. Good luck with whatever you choose, and if it's MT related, feel free to ask any questions and I'll try to help as best I can.
Beyond that, the main things I have left to complete off the top of my head:
- Finish welding the strut tower area I had to cut for clearance of the alternator pulley
- fabricobble my engine mount brackets
- route wiring and connect to PCM as well as integrate with Z34 chassis wiring
- obtain a LS7 MAF (preferably) though I can use the LS4 to start I suppose
- connect exhaust
- install a bigger fuel pump; likely a Walbro unit
There's likely some more odds and ends, but I am confident of starting it up and driving it around this summer.
The other aspect is the tuning and wiring, which if you have access to HP tuners, you can take care of. Since there is no manual transmission tune file for a 3800 W-body, I had to do a couple things: jumper the transmission range switch wiring to [D] range (or you could leave it connected I suppose and just manually toggle it), and then disable the automatic transmission related fault codes in the tune file. After that, the car drove perfectly fine, including cruise control working.
That's about it off the top of my head for the main items. Feel free to ask anything else about it.
Thanks for the reply Carkhz. So... I currently have a 5 Spd Getrag 282 transmission. Am concerned about it not being able to handle the load of SC3800 with Cam upgrade, 3.2 pulley and other goodies. I understand a lot of people have had good success with the 282 as long as its not abused (and some have mated it to V8's).
I purchased a few items for this Getrag 282 last year. However, I'm in the process of getting a 5 Spd Getrag 284 from a 93 Chevy Lumina --- Just concerned about the torque issue with the 282.
Would these parts that I purchased for the Getrag 282 work with the Getrag 284?? Or have to get all different parts?
1x SPEC Flywheel for Getrag 282
1x SPEC STAGE 3+ Clutch for Getrag 282
1 x Getrag V-6 5 Speed Transmission Replacement Cables
1 x V-6 5 Speed Getrag Aluminum Slave Cylinders
1 x Cast Aluminum Clutch Master Cylinders
OR would I need all different / new parts??
Also, I think the Spec Flywheel might work with the 284?? But the Spec Stage 3+ Clutch will need to be changed --- Not sure??
Some info. I found out...
- 284 requires different axels than 282
- 284 will not bolt up to the same mounts
- 284 has a throw out mechanism for a pull-to-release clutch which would require work to adapt a conventional clutch
- 282 pushes the TOB to activate clutch
- Some say... 284 clutch wont work with the 282 clutch
- would need Hydraulics for the 284
Overall, I'm trying to understand what I need to get and or modify to get this working with the SC3800??
Anyway, to be perfectly honest, I'm not certain of all the differences between the 282 and 284 besides the transmissions themselves.
The flywheels appear to be different between the 282/ 284 cars, but I cannot confirm. I'm just glossing over part numbers and they are different. However, it may be moot if you're adapting them to a 3800.
The shift/ select cables may be interchangeable. I know they're the same connection at the shifter end as I initially wound up with a 282 GP shifter in my Monte before sourcing one from a Lumina Z34. The transmission end may be differnent, but it might not matter: My select cable bound up on a test drive and snapped off. I ended up finding an open-end ball joint (aka: Heim joint) that was a perfect fit for the cable end.
The slave cylinders are completely different, as the 282 uses a standard push-type clutch, whereas the 284 uses a pull-type. As such, the clutch kits are different; specifically the pressure plates. The clutch discs themselves may or may not be the same, but again, I've not been able to compare outside of checking part numbers. The clutch master cylinders should be the same though.
The axles may or may not be interchangeable. Most of the interchangeabiltiy issue is with guys swapping from auto to manual (like I did). There are some tricks like swapping inner and outer CV joints, but I believe the best option is to source from the donor vehicle.
I can't think of much else at the moment, however if you check out W-body.com and the Grand Prix forums, there are a bunch of discussions that go into more detail. Good luck!
