Well the gas is on the SS
R/T .064
60 2.315
330 6.184
1/8 9.395
mph 76.67
1000 12.146
1/4 14.459
mph 95.87
So not very good. How do you guys get it out of the hole? It spins so bad all the way through 1ST, I tryed to go EZ on it and it still did it I think that the track was cold 45f out side. I did beat a Dodge Magnum with the 5.7, All well I had a great time oh and the NOS system had a bad switch and did not work next time ....
Steve (Twisted1)
Leave the line on 1/8 throttle and ease down in a fluid motion at the same time say the word Hippopotamus, trying to time the pedal hitting the floor at the end of the word..I dropped from a 14.1 to an immediate 13.905, with a best (an hour later) of 13.811 @ 100.96 with a 2.06 60'...That is the key, with the GXP's wide front tires and stickier compound we have to do this to avoid the TMS (Torque Management System) so it dosen't fall on its face 30' into the run (I almost ate the steering wheel a few times, plus it's very embarassing), but with your car having thoses harder compound tires plus about 2.5 inches less contact patch your problem is different but will be remedied the same way...Keep us posted, also on ClubGP.com
Chris Green
i had a open cone K&N 9inch filter, and resonator removed with dynomax ultra flow mufflers. no track prep and had half a tank of gas. def get some kind of filter setup other than the airbox.
also. i didnt do it because i was lazy. but it seems 26psi in the front tires seem to be the best for traction off the line. somewhere in that ballpark.
i belive tony ripped a 2.011 60ft correct me if im wrong tony.
in the end though the imp should technically be alittle slower. not having tapshift, and also weighing alittle bit more. either way. having 3 cars all with the exact same internals should create a huge aftermarket for us. Intense has made a custum FWI kit for us and also is working on some rockers. WOOT!
) was a 2.06, as for the "LESS ROTATING MASS", to me would be negated by no "MANUMATIC" like our tap shift, also my HUD helped me at the end of the 1/4, 101mph "Click" 3rd gear!!! It shifts fast
!!!! Don't get any easier than that, If I went by the "UPSHIFT" light I would've shifted at 95mph...From the look of his MPH, his car needs to brek in a little more, cause that's way below its potential..
Personally, I'll stick to the road course *if* I race this one at all.
Chris Green
