New site for us
Old Dec 4, 2005 | 03:12 PM
LS4 GXP's Avatar
Default New site for us
Chris Green has been working on putting together a site for the LS4 W-bodies, and opened it up just a little bit ago. You can check it out at www.ls4wbody.com
Hopefully if we get a pretty good sized community built up, it will help leverage some companies into developing products for us.
Old Dec 4, 2005 | 04:35 PM
Jayzvette's Avatar
sweet I'll have to check it out
Old Dec 4, 2005 | 05:00 PM
Dales396lt4's Avatar
Well I can't post rrrrr They wont let me IN...
Old Dec 5, 2005 | 12:25 PM
LS4 GXP's Avatar
did you get the validation email and click on the link to activate your account?
Old Dec 5, 2005 | 07:41 PM
I did not get the validation email.
Old Dec 6, 2005 | 08:49 AM
LS4 GXP's Avatar
The site says "validating" for you. Try going here http://www.ls4wbody.com/forum/index.php?showuser=13 and poke around, try and find a way to resend the validation email, and double check the email address you used. Hope that helps.
Old Dec 6, 2005 | 09:11 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Good luck on the new site, but you won't find a better site than this one for learning about the engines in those cars
Old Dec 6, 2005 | 06:15 PM
LS4 GXP's Avatar
Yeah, the technical knowledge here is great. I think the point of the other site is just to gather all the LS4 owners in one group, so that we can show the aftermarket vendors that there is plenty of interest in mods for the LS4
Old Dec 7, 2005 | 09:06 PM
Nine Ball's Avatar
LS1Tech Co-Founder
There are plenty of mods already for the LS4. Ported heads, cams, rockers, etc...
I guess you are looking for headers and cold air intakes. Those are bound to happen, mostly from the Impala SS loyalists. We pretty much have all the key LSX related sponsors and manufacturers here, and they are easy to reach. Send a few PM's to the ones that make those parts (like Vararam perhaps) and get him a local car to volunteer. Patrick is a good guy, he would probably design an intake for those cars.
Old Dec 8, 2005 | 07:18 PM
TonyGXP's Avatar
I didn't know the truck 5.3 was an LS4?? Is it?? I was under the impression the truck 5.3 was a Vortec 5.3 (no LS designation, not sure of the "code"), I thought the LS4 is an all aluminum engine and about an inch shorter in length to fit in our car's?
Old Dec 8, 2005 | 09:07 PM
LS4 GXP's Avatar
The truck engine is not an LS4. You are right, it's a Vortech. The codes I've seen are LM7, L59, and L33.
Old Dec 11, 2005 | 09:19 PM
LS4WHORE's Avatar
Yeah..Them other forums have just gone to complete crap.
Old Dec 11, 2005 | 11:09 PM
LS4 GXP's Avatar
The 5.3 section at ClubGP is still pretty good, and LS4wbody is too new to compare to any. We'll have to see how it does. I really like the info available here.
Old Dec 12, 2005 | 11:58 AM
LS4WHORE's Avatar
Pretty good with about 8 threads. It's turning into Club Gay Pride over there. Ever since Mr.Green got on his high horse it has gone to crap so I hope everyone moves here.
Old Dec 12, 2005 | 08:00 PM
Nine Ball's Avatar
LS1Tech Co-Founder
The LS4's parts are interchangeable with most of the other LSX based engines. Just like LS1 heads will bolt onto an LS2 and vice-versa. Many of us use 6.0L LQ4 truck heads on our LS1s to drop the compression ratio down for boosted applications. Basically, if you have a Gen III or Gen IV smallblock V8, just about all of the internal parts are already developed.
Anyone have any pics of the LS4 outside of a car? Or at least with the intake manifold removed? I'm wondering if it is LS1 based or LS2 based. (gen 3 vs gen 4).
So, you guys should have these available:
-stroker kits
-ported heads
-camshafts
-intake manifolds
-lifters
-timing chains
-rocker arms
All that is really needed is headers and a cold air intake, the rest is already developed.
Who will be the first to stick an LS-based 454ci into their new Impala SS
Old Dec 12, 2005 | 08:41 PM
Do you guys have DOD? It is not the same, the cam is not even close to the LS1/6 or LS2, and the intake opening & (TB) is on the back side of the motor, too many things to list and the list is long...
-camshafts
-intake manifolds
-lifters
all of these will not work oh and ON PCM MODS
Old Dec 13, 2005 | 12:06 PM
TonyGXP's Avatar
Dale beat me to it.........If it were only that easy, we can't use anything from the other engines of value, between the FWD application, shorter overall length & DOD...that SUX!!!
Old Dec 13, 2005 | 12:56 PM
SG GXP's Avatar
Wow an angry, uninformative and unprovoked flame. Sounds familiar. Could it be...
Originally Posted by LS$*****
What kind of gas mileage you get with the SS,I'm debating on going to pick one up but the dealers don't have any yet in Canada. Is the AWD alright in snow?
Yes it's 04hemiboy.
Where's the block button?
Old Dec 13, 2005 | 01:11 PM
Jayzvette's Avatar
-stroker kits
-ported heads
-camshafts
-intake manifolds
-lifters
-timing chains
-rocker arms
The 5.3 LS4 does have 243 casting heads on it. Which means there LS6 units.
Old Dec 13, 2005 | 01:35 PM
LS4 GXP's Avatar
And I believe the LS4 is a Gen 4 block.
