where is the BCM in a 06 impala ss
Old Dec 14, 2005 | 12:59 AM
Jpr5690's Avatar
Default where is the BCM in a 06 impala ss
Im tring to find my BCM to fix my tire pressure sensor problem.. but i dont know where the bcm is!!!! ... Can someone please tell me where the BCM is and also verify the tire pressure sensor send their signals BCM...
thanks,
john
Old Dec 14, 2005 | 07:10 AM
REDWS6ROCKET's Avatar
Below the left side of the I/P, left of the steering column
Old Dec 16, 2005 | 05:54 PM
Jpr5690's Avatar
whats an I\P?
Old Dec 16, 2005 | 05:56 PM
Jpr5690's Avatar
and just to verify; the bcm controlls the tire pressure sensors ...????
Old Dec 16, 2005 | 08:37 PM
LS4 GXP's Avatar
I/P is intrument panel I think. I'm not sure about the other question, but I believe so.
Old Dec 17, 2005 | 12:23 AM
punch's Avatar
umm, how ya going to fix the monitors? don't you have the shop manual??
Old Dec 17, 2005 | 01:10 AM
Jpr5690's Avatar
actually, i dont even have an impala im posting all this to help a freind... BTW what you mean about fixing monitors.. i just wanna check out the bcm or whatever is controlling the signal to see if i can visually find any problems or mabye just replace the module and see if the problem stops
Old Dec 17, 2005 | 03:00 PM
LS4 GXP's Avatar
There aren't any physical monitors for tire pressure, it's all done using the wheel speed sensors. If one wheel is low, it will rotate slightly faster than the other three.
Old Dec 17, 2005 | 04:32 PM
Jpr5690's Avatar
god dammit, which one is it!!! some of you all say it does use sensors.... some say it dont ...this is for a 2006 impala ss
Old Dec 19, 2005 | 08:46 PM
LS4 GXP's Avatar
Check the owners manual. IIRC there's a short blurb about the way that the system works (wheel speed)
Old Dec 19, 2005 | 10:11 PM
Jpr5690's Avatar
yea my buddy got clocked doing 85 tonight while he swears he was 70-75mph so somethin is up
Old Dec 20, 2005 | 08:09 PM
AdioSS's Avatar
it's still under warranty. Take it to a dealership.
Old Dec 21, 2005 | 05:39 PM
ericguy320's Avatar
That was on the 05 and older, the 06 uses the tire preasure sesnors in the wheel using the ecm, bcm, ipc, and the remote control door lock reciver. but yeah take it to the dealer unless the tire is low there is nothing you can do for it.
Old Dec 22, 2005 | 10:30 AM
LS4 GXP's Avatar
Thanks for the info eric, good to know that it was different in the 06's.
Old Dec 22, 2005 | 04:51 PM
TonyGXP's Avatar
My Service Manager says that the GXP's use pressure sensors?
Even the 05's, are you including them or are you saying 05 impala's have the old way?
Old Dec 23, 2005 | 06:05 AM
Dales396lt4's Avatar
Tire preasure sesnors is in the valve stem of the tire, Same as the Corvette. Just some more info..
