DoD reprogram?
Old Jan 6, 2006 | 05:52 PM
2000KCTA's Avatar
Default DoD reprogram?
My parents have recently purchased a 2006 Impala SS with the displacement on demand. They really like it but want to know if there is a way to change the computer programming to make the V8 kick in less aggressively during highway (example: when on cruise control and the road starts to go slightly uphill, the car kicks into V8 mode...my dad thinks that it should stay in 4cyl mode longer)
Old Jan 6, 2006 | 08:07 PM
Jayzvette's Avatar
They will be able to modify the dod tables eventually. As of now there is no program to do this. I'd like the option of being able to have the computer disable dod when in and using tap-shift mode
Old Jan 6, 2006 | 08:25 PM
TonyGXP's Avatar
That is the reason why that light that tells you what it's in was a BAD IDEA!!!!
and boy am I glad I don't have it in mine! (or I'd be doing the same thing, you watch, that light will be gone by next year, bet you the dealer has to take in numerous complaints about people claiming that exact problem/question.
Old Jan 6, 2006 | 09:45 PM
GTPprix's Avatar
You'd be suprised what we can program
Old Jan 6, 2006 | 10:43 PM
spy2520's Avatar
my car feels the same way but its not the same (and of course i dont have DOD), my cruise control hits the gas a little hard, harder than i would expect but it may just feel that way because i have headers and a cutout, maybe since you know its doing it you might be exaggerating it in your head a little.
Old Jan 7, 2006 | 01:22 PM
TonyGXP's Avatar
with a tall axle ratio the Torque Converter lock-up is more pronounced right around the speed you guys are saying, so I wouldn't be surprised if that were the case.
Old Jan 7, 2006 | 07:51 PM
LS4 GXP's Avatar
Why would you want it to stay in 4-cyl mode longer? You'll end up dumping more fuel in there to maintain the speed with 4, probably just as much or more than you'll use with all 8. Plus I'm sure running those 4 cylinders under higher engine loads will be a lot harder on the engine.
Old Jan 8, 2006 | 09:35 AM
2000KCTA's Avatar
Not surprised since between my dad and myself we have over 35 years of collective computer experience.
Dad thinks that the solution lies in the vacuum settings.
Old Jan 8, 2006 | 10:10 AM
Dales396lt4's Avatar
Just give me a way to turn it ON/OFF and I will be happy.
Old Jan 8, 2006 | 12:46 PM
LS4 GXP's Avatar
the DoD triggers off the engine load, so once you can get in there with a programmer all you'll need to do is raise the maximum load value for DoD operation, I would think. I still don't think it will gain you anything, gas mileage or otherwise. He's definitely in the minority, as I think most are wanting to know how to stay in v8 operation more
Old Jan 9, 2006 | 04:26 AM
2000KCTA's Avatar
V8 mode is fine for stomping it around town or when passing, but when just cruising at 65 or 70 on the interstate it sucks down the gas. GM really dropped the ball by putting the tired 4 speed auto in there. A 5 or 6 speed auto would have saved just as much highway gas mileage as the DoD is supposed to.
Old Jan 9, 2006 | 05:25 PM
Jayzvette's Avatar
I agree. Hell they even put a 6spd auto in the Duramax diesel
Old Jan 9, 2006 | 05:26 PM
Jayzvette's Avatar
I agree. Hell they even put a 6spd auto in the Duramax diesel with 650 lbtq
Old Jan 11, 2006 | 08:55 AM
06MonteSS's Avatar
LS1Tech Sponsor
the DOD works off the oil pressure... and only kicks in if you're in D (auto-overdrive), going 20mph or faster, and cruising along with no engine load or acceleration...
http://www.popularhotrodding.com/fea...0405phr_gmdod/
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jan 11, 2006 | 09:48 AM
GTPprix's Avatar
And it's also electronically controlled.. which we can control Maybe we'll make that part of the tune we are releasing.
Old Jan 11, 2006 | 10:50 AM
06MonteSS's Avatar
LS1Tech Sponsor
Cool! what's the tune going to do/offer ?? something that can be used for/done to the Monte SS 5.3 too??
__________________
Old Jan 11, 2006 | 11:32 AM
GTPprix's Avatar
Head over to ls4wbody.com , thats where we are doing all the Q&A and release stuff.
Old Jan 11, 2006 | 12:17 PM
2000KCTA's Avatar
Thanks
