Bought a new MC-SS, started tuning already
Looks like it will be fun to change, as one bolt is pretty concealed near the ex manifold, and not to mention the massive amount of coolant it will **** upon removal LOL. Better than running at 200 degrees all the time and having 90 degree IAT temps regardless of ambient.
Thanks for the info... didn't know the LS2 t-stat would work. Probably will get a 160 or 180 myself. Needs a transmission cooler too, ive just been to cheap and lazy to get one so far.
I had a guy take professional shots of both car this weekend, i get the CD from him today. Ill post more of the JUST monte later. Gonna try to get the Camaro in GM hightech with these, maybe the monte too at the same time if i do some more mods to make it worthwhile hahah
Some of you with sharp eyes will notice the slight visual changes for the better i made to the monte.
I haven't messed with any of the other torque values under engine torque management yet.
Basically just doing what you guys have done so far(shift points, rev limiter).
Also wondering where you guys are getting rid of the torque managment? There a few areas that can be adjusted from the looks of it. Is it in the engine tab or transmission tab?
Really awesome product!
In the transmission torque management I set both abuse mode tables to 0 in all fields. In the torque reduction tables I set the 1>2 and 2>3 shifts to 0 in all fields for both normal and perfomance mode. I removed about 80% of the torque reduction for the downshifts.
However after I removed all that torque management I noticed it was not grabbing good when shifting during heavy throttle.(kinda shuddering) So I bumped up the shift pressure tables a bunch. I have 1st gear at max pressure at 207 ft lbs and higher... then smoothed it down to the lower torque values. Did pretty much the same thing with 2nd gear except I set 85 at the highest value. Basically I added alot to the mid-area of the pressure table. Once I got the normal table looking like I wanted I just copied it to the other 3 pressure tables. (im not sure what the "power/brake on" tables are for) Also copied it to the 2 downshift pressure tables.
I really shifts good now at full throttle... I still have alot of driving to do to see if I like it though.
Set the WOT shifts at 49 mph and 6100 rpms... and the rev limiter in gear at 6200 rpms. Even with the 49 mph shift speed it still shifts a few mph higher. That took some messing around to get it close to the rev limiter without actually hitting it.
Don't know if anyone else has the problem, but my TCC was slipping under very light throttle above 60 mph. I multiplied the lower TCC duty cycle table by 2 and it has stopped.(thanks GM)
Also on mine the minimum and maximum TCC duty cycle are labeled backwards. It is pretty easy to see cause the low values are in the maximum table and high values in the minimum table. Just ignore the names.
Adjusted the fans to come on sooner. Changed just the table based on ECT. It keeps it a little cooler, but not much.
Of course I set the speed limiter to something higher than 140... I think 155 or 160... can't remember.
Did a bunch of adjusting to the part throttle shifts. You just have to adjust them to what feels best plus they also need to sorta match how your full throttle shifts are set.
So far I haven't done anything to the engine tuning... I have a wideband just been to lazy to install it.
I looked over the scanner charts and timed 30-60 mph before and after (this includes the 1-2 upshift. On the 2 runs I compared so far just doing what I did so far reduced the 30-60 time by .4 second!
It was hotter on the day of the stock run, but still, something to consider. I'll do some same day tests later, but I thought I would mention this for anyone thinking what doing some tinkering would do. Gets rid of the noticable power drop in shifts for sure, I'm impressed. HPTuners.com. The low octane table has lower timing settings mapped to it, so I would think if the engine sees spark knock it will switch to the low octane table and the corresponding reduction in power. I've always put premium in, so I dunno if it noticable seat of the pants wise. At maybe $5.00 a fillup more for premium, why bother with regular unless you are just going to sit on the highway?
I think I'll correct a little bit of internet rumor I might be starting here....I looked over some more runs and that .4 second might not be true afterall, so please ignore this boastful remark!
I tried out dropping the tranny torque management in shifts to 50%, but looking over the line charts for the runs, I kinda get the feeling that the tranny is starting slipping some after the 1-2 shift with 50% TM removed. Nothing major, it grabs after the shift, but comparing full TM with 33% removed and 50% removed, I feel more confident in leaving 33% TM removed in the car. The 33% removal makes my issue with how the TM works disappear, so I'm happy.
Normally its disabled on other LSx cars due to it being illegal to use in the states because of an increase in NOx emissons, But the table was in place, so it looks like they used it for the DOD controls. im gonna try and bump up the settings to make it stay in 4 cyl mode longer and not switch as much. Around here we have rolling long minor hills on the free way and it constantly switching.
Right now (stock) anything above 25mph and less than 20 % throttle it will engage. So im going to bump it up to 30% once and see what it does.
that isnt the DOD, that is the fuel cut off when u let go of accelerator. as of now u cant adjust the dod on the car
DFCO stands for decel fuel cut off...
however they DONT use this on U.S. issue cars due to the fact it increases Nox emissions from a leaner mixture.
It is a convienent place to put the controls w/o making another tab and makes sence to me.
I moved mine up to 40% throttle to dissable and raised the g/cyl for the maf input like 15%
And sure enough.. scanning it shows it disengages right at 40% throttle when cruising around town or a higher g/cyl than what i have in there (more engine load)
what the hell does the credit thing mean?!?!?
im pokin around the hp tuners site and see the credit deal. is this how many times you can flash the ecu? or different amount of cars?
what package did you guys get?
This has no effect on how many times you can flash the computer. Ive probably done it 50-60 times now. You can keep flashing it till the world ends.
Besides there are a ton of variables that the computer takes into account to decide when to use DOD so I would imagine that GM would have to have wrote specific code for it. Plus the guys at HP Tuners said they hope to incorporate some DOD settings in future releases.
I have no proof... I actually have no idea at all. Just doesn't seem logical.
Also just curious... what are you logging that would show whether DOD is on or not. I never really found anything definite. I just kinda judge based on sudden changes in MAP and MAF output.
