Bought a new MC-SS, started tuning already
Took advantage of the 0% financing and went ahead and got one. Victory red, ebony leather, no sunroof.
With 120 miles on it i had started the tuning process. I have HP tuner's i use for me Camaro, so i bought some credits and started tweaking the Monte.
So far i just removed the stock air box, installed a 10" long cone filter on the end of the MAF and tweaked the MAF table to reflect the air filter was reading +8 LTFT's after the filter, now its about -3 which is perfect. Played with the force motor table and reduced the #'s by 10% and that got the shift firmness pretty nice. Raised the rev limiter to 6300 from 6100, and raised the shift points to 6100 instead of 5800. and got rid of the hell forsaken torque managment
I tried turning up the wick on the timing (only about 18* at WOT) but the dealer had filled it with 87 octane so i was greeted with knock retard by 3-4 degrees consistently. So once i have a tank of 93 in it i will try it again.
But it shifts great now at WOT, almost chirps the 1-2 and never stops pulling after the shift.
I love how loose the converters are in these cars!!! its gotta be like a 2800 stall stock in these things!!!
Normally its disabled on other LSx cars due to it being illegal to use in the states because of an increase in NOx emissons, But the table was in place, so it looks like they used it for the DOD controls. im gonna try and bump up the settings to make it stay in 4 cyl mode longer and not switch as much. Around here we have rolling long minor hills on the free way and it constantly switching.
Right now (stock) anything above 25mph and less than 20 % throttle it will engage. So im going to bump it up to 30% once and see what it does.
www.hptuners.com
1. Will a mass airflow translator for an LS1 work with these cars??? I used to make A/fF ratio changes with that and autotap software by montroing LTrims.
2. Is there a 10" cone filter specifically made for our cars or did you improvise? I'd love to delet the airbox. I also may have a ported mass airflow housing for an LS1 laying around, wonder if it would work.
The filter i had laying around, it was off my 04' Colorado. It has a 3" or 3.5" opening... cant remember. but i removed the air box top half, the bottom half holds the PCM and TCM. And unscrewed the maf from it and removed the O ring and clamped the filter on to the maf.
I dont pound on the car all time so i think the trans will be fine. if it fails, the stock tune goes back in and goes to the dealer.
...is there any way to trace someone dinking with the tune should the dealer check? I take it HPTuners is the tuner of choice or would some other brand be better to get? Thanks guys
Nice solid Laser blue car! i almost bought that identical car.
The timing tune came along nice! the car F-ing rips!! time to get this thing to the track.
www.hptuners.com
You say the DFCO tables control DOD? Im probably gonna mess around with them soon. Don't you chevy guys have a DOD activation light or something? if so can you tell if the changes you made did make a difference?
I dumped all the torque management for 1>2 and 2>3 shifts and all downshifts and increased the shift pressure. Only thing I don't get is there is no shift quickness setting. Either they have not been added or the TCM doesn't even have those tables. Checked an LS2 GTO bin and it doesn't have them either.
As far as the maf sensor goes. Like you im thinking about using a Z06 or LS2 maf. I think they are pretty much the same thing. The Stock one on these cars are pretty crappy in my opinion. I had a 2001 silverado 4.8L that had a bigger, smoother, and better designed maf than this thing.
Actually have the K&N air intake from that truck, the filter part of it will bolt right up to the Z06/LS2 maf. So I will probably be using it.Anybody else notice the horrible intake manifold? Seems it is as poorly designed as the LS2 manifold... only smaller. Plus we have a 4 bolt ~76mm throttle body... so no other manifold will bolt up as of now. Im thinking about getting an LS6 intake and getting TPIS to put a 90mm flange on it then using a LS2 throttle body and maf. All that is gonna be expensive though. Probably be a while before I can afford it.
This keeps it in 4 cyl mode alot longer, it pulls up hills just fine it seems, the T/C locks up and it kinda pulls hard when the cruise is on a comes up toa slight hill, stay in 4 cyl mode and the mpg drops to like 20.
But it doesnt seem to keep it in too long, it takes nothing to get it over .28 cyl/air so it still lets all 8 run when its TOO big of a hill.
So far im about 230 miles to a half tank, with driving it as nice as i can for now.
Yeah i was wondering about the shift times table too! when going up through the gears, it gives a nice bump but u can tell it has the normal .5 sec delay in the shifts yet.
[/IMG]
