Swaybars available??
Yea, thats what I'm thinking... it's just too early, maybe in another year or so
Anyone installed them?
Had a '98 Regal GS SC, poly took that roll out of it, and was a cheap fix as well. Don't really remember that ride quality was diminished, since that was in '98 - 2000.
Based off my favorite on-ramp and S-curves, the MCSS hits "slalom" speeds that I find acceptable in a 3500 lb family car. Ride quality is good except in the patched up areas on the highway, then hold on to your pop! Also can't say anything bad about the Goodyear GSC's ... I usually replace the stock with BFG's, but I don't feel the need to @ 38 - 40 PSI hot.
Thanks for the info. When I bought the impala, the sales guy told me the the MC with the FE4 was alot more aggressive. I've been looking for a wrecked MCSS I could get the sway bars from... Glad I didn't find one, it wouldn't have done much good. Hopefuly someone will come out with some aftermarket bars.
Do you know if the GXP has the same sway bars as the FE3 & FE4? I'm guessing the bars are the same on all 3.
40 PSI hot pressure / front
The poly takes just about all of the flex out of the bar movement, transfering the energy from the endlinks straight to the frame.
http://www.energysuspension.com/pages/chassis.html
Summit Racing Equip - Endlinks: $13.69; Swaybar: $13.95 "ballpark pricing". Need measure the bar size and the length of the EL's. Installs in a 1/2 hour.
You won't be sorry.
http://www.gmcanada.com/english/vehi.../mont_opti.jsp
http://www.gmcanada.com/english/vehi.../grpx_opti.jsp
http://www.gmcanada.com/english/vehi.../impa_opti.jsp
Bar info toward the bottom ...
What are you doing with your car that you need to change bars? Kinda watched curve / ramp speeds tonight, my MCSS (w/ stock suspension) exceeded recommended speeds by over 20 mph. Are the Imp's that far behind the MCSS and GXP?
That GM Canada info is different than even GM techs can dig up...according to that site:
-The Imp has a Solid 34mm front and a hollow 19.4mm rear?
-The MC has a Solid 34mm front and a solid 18mm rear?
-The GXP has a 20mm front and 17.2 rear?
Isn't this the same corportation that said (on it's site) the 2006 GXP had the 3.8S/C engine? LOL
Here's the poly for the 34mm (for those who are interested):
http://store.summitracing.com/partde...5&autoview=sku
Last time I will mention it. $12.50 - jack up the front, take off the tire, install in 5 minutes. Better handling. Greaseable is quieter, if you are interested just call Summit and they will find them for you. While you've got the tire off, change out the grommets on the endlinks as well. All that you have to do there is remove the nut from the bolt, and disassemble / reassemble. Very easy. Get rid of that body roll.
Then go out and buy some BFG G-Force KDW 2's:
http://www.tirerack.com/tires/tires....1=yes&place=10
(Save the Goodyears for winter)
Have fun carving up ramps / curves!!!
BTW - my Camaro SS came from the factory w/ poly.
Edit - check out this test article w/ the BFG's:
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=35
Notice the "lean" on the Lexus.
Thanks for the link to the summit site. I checked the energysuspension link from your earlier post and didn't see anything for the 06 Impala. So then I started looking for something that might be close.
I started this thread because I didn't want as much lean in the corners. I like hitting the on/off ramps pretty quick as well as some back roads to work, the IMPSS holds the curve well but leans like crazy(in my opinion). I put some hotckis bars on a fullsize GM truck and also on an IS300 and each handled better. Don't know if I took the turns any faster, but I liked the way they felt in the turns after installing the bars. I'm never satisified with cars... I can't leave well enough alone and HAVE to change something. Usually start with the suspension and then more hp. I'd love to have a vette but need to have a back seat to haul the family around... so here I go again with the IMPSS.
Buffalo:
Thanks for getting the facts on bars for these cars.
With the fam, did the '98 Regal GS before I bought my Camaro SS (read "4-seater" BTW). On a waiting list at 2 dealerships for a ZO6, but still on the fence, as I would have to pick which kid will go. Ironic though, as my Camaro pulls so hard now neither want to go in it! There's only a couple of cars out there from GM and Chry for V8 car guys with families. At least they are building them again.
I got this MCSS as a "me" buy, meets the minimum req's of 3 seats, 2 doors and a V8. While it may do 3/4 of the things the Camaro can do, it's a darn nice daily driver to take care of my wants. I'm usually depressed when the big-dog is in storage, but the MCSS is a great stop gap. Thought I wouldn't tweak on it, just drive it, but I was WRONG!!
Keep the faith! I hear so many guys say they need a minivan because they have a kid - remember to take care of yourself as well! Keep your passion for cars! Keep wrenching - let me know if I can help!
