rockers
Old Oct 18, 2006 | 06:15 PM
Area47's Avatar
Default rockers
anyone change em out yet?
if so, what ratio did you do?
i really am getting tired of being the test monkey
Old Oct 18, 2006 | 06:45 PM
SDfbody's Avatar
Looks like they used 1.8 rockers
http://www.vincihighperformance.com/IMPALASSPARENT.HTML
Old Oct 19, 2006 | 06:36 AM
KillaGXP's Avatar
PHP Code:
VHP  1.8 ROCKER & SPRING INSTALL
GAINS OF 18.1 rwhp & 16ft lbs tq
did i only notice the rwdh in that?
Old Oct 19, 2006 | 07:57 AM
SidewaysLS4's Avatar
Impressive for sure, but the thing I really hate about a before and after graph is that you really have no idea of what the engine operating parameters are for the two runs. For example, you could do a pull on a warm motor with good IAT and coolant temp and get some excellent numbers. Then you could do a pull when hot and get crappy numbers after the PCM pulls maybe 12 degrees of timing due to coolant temp and IAT thermister cooking. You really couldnt get an accurate idea what the part did to improve performance, at least if you werent monitoring these areas. I'd like to see a dyno chart with some readings of what the PCM is seeing as well. Nothing against these rockers, but I thought I would throw in my .02.
Old Oct 20, 2006 | 03:50 PM
Mike's 01WS6's Avatar
Need some track testing too.
Old Oct 21, 2006 | 05:53 PM
eddiemoney's Avatar
Nothing is proven in my mind without track testing
