Front Headlights (O)(O)
Old Nov 16, 2006 | 04:23 PM
Tony_SS's Avatar
Default Front Headlights (O)(O)
Am I the only one who thinks my black 06 SS looks like one of those black goldfish with the bug eyes? I need replacements or some serious black vinyl.
Old Nov 16, 2006 | 04:43 PM
Richiec77's Avatar
https://ls1tech.com/forums/ls4-performance/567811-i-ve-been-pirated.html
Check that out. Someone did something to change the look. You might like it too.
Old Nov 16, 2006 | 05:18 PM
krazyglu's Avatar
i think that just makes it look like the car is squinting
Old Nov 16, 2006 | 06:11 PM
Area47's Avatar
it needs glasses, it can't read so good
Old Nov 20, 2006 | 12:04 PM
BuffaloSS's Avatar
After more than i year with the car, i still don't like how bug-eyed the Imp looks. The MCSS doesn't look nearly as bad with the same headlights due to the more agressive bumper/valance combo.
Old Nov 20, 2006 | 01:20 PM
Tony_SS's Avatar
Ive decided to cover the whole headlight in black vinyl and cut out a series of holes for the headlights/marker lights... stay tuned.
Old Nov 20, 2006 | 02:26 PM
BuffaloSS's Avatar
Funny you should mention that...this thread got me thinking about it again and i went to the store to buy some pinstriping and painting tape so that i could do the same with paint.
I'd say "Good luck" with getting the vinyl to lay properly over the complex curves that are our headlights, but you're the vinyl guy, right? Who needs luck?!?!
Old Nov 21, 2006 | 09:08 AM
hexxLS4's Avatar
I agree...the new lights are bugged out. I, however, went with headlight tinting instead. Right now they look a little brown because I didn't go dark enough....but once I get my HID's I'm going darker. My light output is still fantastic and would prolly be like stock if I merely threw in some silverstars. I'm also going to paint the chrome parts black and paint the emblems black and reapplying the red vinyl inserts (this is just to get rid of the chrome outline that the emblems currently have). Finally, I'll get some black rims, paint the calipers red, MPD ram air intake hood, and maybe do a thin red pinstripe around the ground effects and call it a day. I won't rest until this bugged eyed monte looks scary as hell!
Old Nov 21, 2006 | 11:18 PM
Kazmaniac's Avatar
Anyone thinking of painting the inside chrome of the headlights black, like the last gen Imp or Grand Cherokee??? would want to leave the projector chrome.
I think black headlight bezels on my red car would go well w/ the rest of the black trim.
Old Nov 23, 2006 | 07:25 AM
Tony_SS's Avatar
Im not the vinyl guy, Im the t-shirt guy! There's now way to get vinyl to lay flat on these, and I didnt even try yet. I need to explore other options.
I do like that tint above? was that all done in one piece?? How that go on without pockets?
Old Nov 23, 2006 | 10:01 PM
BuffaloSS's Avatar
Ive considered this, too, but much like the previous gen Impala's, the housing and lens are practically fused together and impossible to open without breaking one or the other...someone said bake at 300* for ten min but not me, thanks.
Ahhh...gotcha!
He had it professionally spray-tinted in Jersey...costly but damn nice looking.
http://www.jonstintedtails.com/index.htm
Old Nov 23, 2006 | 11:12 PM
Kazmaniac's Avatar
You know if they're silicone sealed or maybe sonic welded? Lil' expensive to break 4 sure!
Old Nov 24, 2006 | 01:07 PM
BuffaloSS's Avatar
There's some sort of black sealant between the two...not sure how strong it really is. If you remove one and look at it, you'll notice there are clips holding the lens to the housing...on my "test" headlight i tried cutting the sealant with a razor but couldn't for the life of me get them apart. I really dislike the chrome in the housing.
On another note, i just finished painting the lens after masking off the headlight & signal areas...but haven't taken off the masking tape...time to do that.
I also just re-did my taillight with the VHT niteshades spray tint. I went too dark the first time and used less this time...looks good but i have a couple runs i'll need to wet-sand before it's complete. Unfortunately, with the VHT, you really need to go on thick to get full coverage, and by that time it's almost TOO dark. I'll get a few pics once i finish.
[EDIT: Well, I removed the masking from the headlight and it looks like crap. Because the lens sits so far away from the housing, you see all sorts of chrome through the areas i left unpainted...just doesn't look good at all. I used goof off to clean it up a bit and think that if i leave the headlight lenses and front blinker open, and cover up the sidemarker, it would look much better...however my daughters misplaced my tape so i cannot mask off what i need to now.
The taillight looks real nice, though, not too dark but dark enough. I got some specks of lint in the tint so i need to do it over again. Also, there were a couple runs so i had to re-do it anyway. Goof-off removed the tint with no problem. I used up the last of the VHT so i'm going to need to buy more.]
Old Nov 24, 2006 | 06:25 PM
gulfstreamcpt's Avatar
Hey HexxLS4;
Where'd you get those headlight covers? Been looking for those and can't find them anywhere. Did I understand that the company you got them thru has different shades of darkness of the smoked ones like you've got?
Old Nov 27, 2006 | 12:08 AM
Kazmaniac's Avatar
Here's the baking method (Camaro headlight as the test subject): http://www.cardomain.com/ride/224386/2. 200* isn't too far off from what test mules hit in desert testing from just the sun.
Old Nov 27, 2006 | 08:38 AM
BuffaloSS's Avatar
Originally Posted by gulfstreamcpt
Hey HexxLS4;
I said it up above... www.jonstintedtails.com He'll tint them just the way you like!
Old Nov 28, 2006 | 01:13 PM
hexxLS4's Avatar
Buffalo SS is wise...I did get it done at jonstintedtails.com
He's a really nice guy and makes sure you get exactly what you want. What you see above is Medium tint. I'm not crazy about it because the lights look brown in direct sunlight. I'm gonna go darker and install HID's.
Old Nov 29, 2006 | 08:56 AM
BuffaloSS's Avatar
I've been looking to purchase another set of headlights to have tinted, so i am not without my (only) car for any period of time. I've tried tinting my own with VHT NiteShades but that's not working for me. I can get the taillight right, but the headlight just doesn't work.
I just bought a set of HID's, so i'm ahead of the game there, only i went too high on the K scale by mistake, and now may need to hold off on the tint.
