Pictures of Exhaust tips for Kazmanic...as requested
Anyways here are pics of the tips...
Jason
Tips look good, are those scratches in the last pic ?
Have to check that out....
Those "appear to be stock", only larger, which is exactly what I'm looking for.
Can you get the manufacturer & P/N from your muffler place? They appear to be clamp on, correct?
I will call them and ask. They are welded right on to the muffler actually.
Jason
I will measure them tonight and check the diameter. The next size up in my opinion just looked too big and did not suit the car...............
I totally forgot to post back about this. I called back like a week ago and asked Hot Rod Scott about the tips, and he told me they are just a generic tip he orders out of a catalogue. They were wrapped in paper basically when I was getting the system installed. No real name or brand on them at all. Sorry I cant be anymore help on this!
Jason
Here's the tip i found for you MCSS owners. It's by MBRP Performance Diesel Exhausts and made of double-walled t304 stainless, 2.5" IN, 3.5" OUT, 12" long - $35/ea - free S&H. As to NOT name-drop, Google "MBRP dual wall exhaust tip" and it should come up as the first match:
BuffaloSS - You nailed it!!! Thanks a million!!!
Got the tips on tonight, installed them after I cut off the rolled ones I added to my MF system. Very clean - very OEM looking. Hated the rolled tips, made the car look way too last-gen. Design and 3.5" IMO is the correct sizing for the car. Mean looking.
Like 99VetteMan said, they're the right length, they don't push past the bumper when the system heats up. Very happy tonight!
I wonder if i got a set (provided i could now that they're sold out there) and had the exhaust shop cut them down to the needed length...then welded up the inner ring of the double-wall to the tailpipe? Maybe weld in the double wall to keep water and crap from getting in there?
I guess i could just buy them and then resell them should i need to.
He will probably ship them to you!
Jason
Length of tip is too long to bend your tails, I cut my tails to 5 1/4" just to mate the tips to them and blow anything past the inner weld / crimp. So the pipes can't be bent, assuming mufflers are hung at the exact same point on both cars.
Tips said made in Canada, maybe call MBRP and ask them if they can fab you a smaller set? If they can't, I'm sure they could point you in the same direction, since they prob competitively benchmark other companies.
I will also search the net to see what I can find. Maybe do what Vette says and call the hot rod place.
Maybe i can convince the wife to let me check to see if everything is in there LOL...grab a tip and take it outside to see how it will look!
but come Saturday, I'll have to tell her it came in, and to wrap it up and put it under the tree... as that's the only present I wanted from her.... told her not to get me anything else, cuz that's all I wanted....
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Quite excited over here! Now, i'm contemplating installing this myself the day after X-mas and having a shop weld it up afterwards...Question is this: Can any shop do this or is there a special setup to weld stainless? I don't want a "hack" at the local Midas/Cole Muffler ****ing it up, you know? But i don't want to spend through the nose to have a few seams tied up either.
Oh, yeah...and the Tips need to go SOON! THese monsters are HUUUUUUUGE!
