Anyone find a solution for squeking headliner?
Old Jan 13, 2007 | 03:42 PM
DUSTYWS6's Avatar
Default Anyone find a solution for squeking headliner?
I have all sorts or creeking and squeking coming from my headliner and I can't find a way to stop it. I stuffed some pillowcase fill between the roof and the headliner and that didn't do any good (may have made it worse). This problem is driving me up the wall.
Has anyone found a way to solve this?
Old Jan 13, 2007 | 05:16 PM
Kazmaniac's Avatar
BSR's come from a number of issues - I have one between the OH console and the S/R opening. More than likely a wire harness that is loose.
Another explantation is glue making contact with the sheet metal. I also think my OHC has weak attachment points, didn't look yet to see if there was a screw holding it in place.
If turning the radio up doesn't work, a trip to the dealer can solve the issue. More than likely they will pull the HL down and have a look under warranty.
Old Jan 18, 2007 | 08:08 AM
npd4432's Avatar
Does your car have a sunroof, my sunroof shade is making all kinds of noise.
2007 impala ss
Old Jan 18, 2007 | 10:13 AM
Area47's Avatar
mine is an intermitant squeak, comes and goes.
may take the liner down and do some dynomat at some point in time.
Old Jan 19, 2007 | 08:58 AM
Dr Octane's Avatar
I put double sided tape under the sunroof trim. Seemed to help.
Old Jan 19, 2007 | 07:35 PM
DUSTYWS6's Avatar
Yeah, I have a sunroof. The sunroof trim is sitting in my backseat and it seemed to help a little, but the squeeking is still there......and it's embarassing to have trim pieces in the back seat of a $30,000+ car to get rid of noises
Old Jan 19, 2007 | 11:33 PM
Kazmaniac's Avatar
That's for sure - put it back together and take it to the dealer.
Old Jan 20, 2007 | 10:57 AM
BuffaloSS's Avatar
I want to say "Link" from NAIOA, occasionally here, had a squeak that was cured by adding a clip to the middle-rear of the headliner. He posted info on it somewhere. Let me go look for it...
EDIT: He said he took it into the dealer and they said the bracket was loose. They tightened it up and all was well. He didn't go into specifics.
Old Jan 20, 2007 | 08:44 PM
DUSTYWS6's Avatar
Good deal, thanks for looking that up. It gives me hope Maybe I won't push this car into the river after all.
