Spring/Rocker/Push rod install pics
CC26918 Ovate Wire Spring Set
PAT8452 Harland Sharp LS1 Non-Adjustable 1.8 Rocker Arms
CC7955-16 Chrome Moly Pushrods 7.400 (Stock Length)
Besides the usual tools, I will also need a spring compressor. I am thinking of getting the Crane valve spring tool that you used BADDLS1SS. I guess I will also need the air hose/tool to hold the valves up. Is there anything else that I would need? Thanks to everyone for the help.
Is there actually a problem with the stock pushrods? Flexing, or is it just one of those ugrades that you might as well do as long as you have done 98% of the work anyway?
on the whp deal, my car was silly lean when i dynoed, there is more power. but i will never know just how much is in there.
I would LOVE to have a 6500 shift point in my LS4 Fiero swap but don't want to kill and replace lifters every year.
Does anyone have actual dyno charts with springs/lifters in an LS4 spinning up to 6500+ rpm?
Will the stock tranny survive behind a 6500rpm LS4?
The engine is out of the car now, so mods will be easier to do, BUT the swap will need to pass an emissions inspection to registered. So will the springs and rockers effect emissions? I know the ECM reprogramming could have some emissions side affects depending on what is done.
