Spark Plug ?'s
Old Feb 26, 2007 | 12:45 PM
Mgpeagle's Avatar
Default Spark Plug ?'s
Hey guys,
Does anyone know a pure platinum or iridium plug that is 1 heat range colder than the factory plugs? Thanks in advance.
Regards,
-Mike
Old Feb 26, 2007 | 01:08 PM
BADDLS1SS's Avatar
Non platinum though... NGK-TR6 plugs are 1 heat range colder.
Old Feb 26, 2007 | 01:48 PM
sprayjunkie's Avatar
+1 Tr6
Old Feb 26, 2007 | 03:24 PM
Mgpeagle's Avatar
Are those Iridiums or just a copper tip? I am confused are they one heat range colder or one heat range hotter? I am looking for colder ones. The last post said +1 so that leads me to believe they are hotter. Thanks in advance.
-Mike
Old Feb 26, 2007 | 03:31 PM
BADDLS1SS's Avatar
A: why do you NEED platinum or iridium?
B: NGK plugs are diff than say champions, the higher the # the colder the heat range. Stock NGK spec plugs for these engines are TR55's, the TR6 is one heat range colder. I beleive they are copper.
Are you going to be spraying?? If so stay away from the platinum etc...
Old Feb 26, 2007 | 04:03 PM
Mgpeagle's Avatar
Not going to be spraying. Personally, I'd like to get platinums for long life. Does anyone know the autolite equivelent to our stock plugs? As I mod I want one heat range colder plug to reduce some potential KR. I did this in my old 2001 GT and it worked out well for me. Thanks in advance.
-Mike
Old Feb 26, 2007 | 04:16 PM
-Mike
I meant I'm for the TR6 as well, +1. It is one range colder than stock.
