Diablo and OnStar ?
Old Mar 12, 2007 | 01:30 PM
Mgpeagle's Avatar
Default Diablo and OnStar ?
I have a 2005 GXP that came with OnStar but it is now inactive. Did any of you who have the Diablo tuner have to disconnect the OnStar fuse even if it is not active? Thanks in advance.
-Mike
Old Mar 12, 2007 | 01:53 PM
06MonteSS's Avatar
LS1Tech Sponsor
if the onstar light is on, on the rearview mirror (I'm guessing that's where it is), then I would disconnect the fuse. If the light is off, then no, you don't have to.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 12, 2007 | 02:09 PM
BuffaloSS's Avatar
Mike, i'm assuming you got yours, then...huh?
Old Mar 12, 2007 | 02:16 PM
Mgpeagle's Avatar
Yes, Sir! It came on UPS today. Correct me if I am wrong but we can't firm up the tranny line pressure on our cars can we? I am hoping we can. I am also wondering if this thing comes with the DOD features to turn it off or not? I know, here I go with all the questions. Thanks for any help, guys.
-Mike
Mgpeagle's Avatar
Thanks again, Chris.
-Mike
Old Mar 12, 2007 | 02:38 PM
kpssmonte's Avatar
Trans updates are being worked on by Diablo and you will be able to adjust you trans when the update is available,to disable the DOD feature just install the no DOD tune ok.
Old Mar 12, 2007 | 02:43 PM
kpssmonte's Avatar
Diablo and OnStar ?
I think you should remove the onstar fuse because onstar can go online when it wonts like for diagnostic report through onstar.
Old Mar 12, 2007 | 04:31 PM
jabronie78's Avatar
I got mine today too. Came with the ac adapter, that was a plus. I will probably just leave the Onstar fuse out since I don't use it anyway. Do you have to download the tunes from the website cause I don't think the newest tune is on here.
Old Mar 12, 2007 | 04:38 PM
kpssmonte's Avatar
yes when you first get it there will be a update on their web site http://www.diablosport.com/index.php...display&pid=68
this is the page with the update.
Old Mar 12, 2007 | 04:39 PM
jabronie78's Avatar
Do you have to remove any fuses??
Old Mar 12, 2007 | 04:42 PM
06MonteSS's Avatar
LS1Tech Sponsor
when you boot it up, look at the revision across the top... should be at least 8r06.. if not, then you'll need to grab the update and software from the website and update your unit to 8r07.
__________________
kpssmonte's Avatar
just the onstar and make sure everything is turned off radio etc.
Old Mar 12, 2007 | 06:17 PM
Mgpeagle's Avatar
I tried to download the tune in the car and got this crazy notice "part number 1269xxx" not found in vehicle database. WTF is that? So in short, I could not download ****! Kind of pisses me off a little bit. Sorry for the rant... Any ideas?
-Mike
Old Mar 12, 2007 | 06:38 PM
06MonteSS's Avatar
LS1Tech Sponsor
Any ideas?? yup - going by diablosport.com's site, there is no tool that supports the 2005 Pontiac GXP...
it's only available for the 2006 GXP...
the only 2005 Pontiac supported is the GTO.
I'd say get in touch with Diablosport and see what they have to say.
Only thing I can think of is that people should check diablosport's site before getting one, to make sure it will work with their year/model of car... just like the 2006 and 2007 Monte/Impala SS - they're not compatible either. Yes, the engines and trannies are still the same, but they (GM) changed something in the computers - so the Predator for the 2006 does not work with the 2007. Sounds like the same type of issue here.
__________________
Old Mar 12, 2007 | 07:20 PM
Mgpeagle's Avatar
Before I even considered one I e-mailed Diablo about compatibility. I received and e-mail back stating it would work for a 2005 GXP. I will e-mail them about this too. Thanks though.
-Mike
Old Mar 12, 2007 | 07:47 PM
06MonteSS's Avatar
LS1Tech Sponsor
The Predator for the 2005-2006 GM LS2/LS4 V8 Vehicles is applicable for the following vehicles:
* 2005 Only C6 Corvette
* 2005-2006 LS2 Chevrolet SSR Truck
* 2005-2006 LS2 Pontiac GTO
* 2006 LS2 Trailblazer SS
* 2006 5.3L V8 LS4 Chevrolet Impala SS
* 2006 5.3L V8 LS4 Chevrolet Monte Carlo SS
* 2006 5.3L V8 LS4 Pontiac GXP
How to verify that the vehicle is supported
The eighth (8th) position in the vehicle identification number (VIN) is the code that designates the engine type. The Predator will support the vehicle if the engine code is:
Car: 8th digit of the VIN= U,C
also, check this forum thread out - guy with a corvette had same issue and it sounds like he had to get his ecm flashed to the latest GM version from the dealer first before the Predator would work with his car:
http://forums.corvetteforum.com/show....php?t=1616735
__________________
Old Mar 12, 2007 | 09:46 PM
Mgpeagle's Avatar
I think Area47 has a Diablo and he has a 2005 GXP. Shouldn't it work for all of them?
-Mike
Old Mar 13, 2007 | 06:59 AM
06MonteSS's Avatar
LS1Tech Sponsor
his ECM may be updated to the latest GM revisions, whereas yours may not be. That would/could make a difference. Check with him.
__________________
Old Mar 13, 2007 | 08:24 AM
BuffaloSS's Avatar
Mike...super sorry to hear that! Hope you can work it out somehow.
Old Mar 13, 2007 | 09:14 AM
Mgpeagle's Avatar
You and me both, Chris... It isn't anyone's fault, **** happens. I am in contact with Johan at Diablo now about this. Thanks for all the support.
-Mike
