ls4 Cam Specs?
Old May 15, 2007 | 10:21 PM
MotorsportsMatt's Avatar
Default ls4 Cam Specs?
I've been researching cam specs for the LS4 and have found VERY little information. Also, I've been studying the cam guides in order to better understand cam selection. While I'm at it, Does anyone know the BBDC for the stock cam?
Matt M
Old May 16, 2007 | 06:33 AM
06 SS's Avatar
"How to build and modify small-block V-8: Camshafts & Valvetrains" by David Vizard is an excellant book to get you started on the basics of camshaft selection. Plenty of dyno tests and real World experience. Covers duration, lift, rr's, LCA, etc. Matter of fact, after you read it, you will figure out that, while theory is good, it is really no substitute for experimentation. Theory will get you close, actually trying it out will get you that last 10%.
Old May 16, 2007 | 08:36 AM
Hehehe. had that book ordered for a week now. Any day it should arrive . I'm really just trying to figure out the stock cam specs or more of a kind of stock "cam card" would be perfect. So that way as I learn more I can have a great reference point to relate the figures to.
Matt M
Old May 16, 2007 | 09:33 AM
06 SS's Avatar
at a guess, with the similar power numbers, and the fact that GM likes the same amount of overlap (for same displacements) , I would say the 5.3 truck cam specs are probably real close. 191/190 (0.466" / 0.457" w/1.7's) 114 LSA
