predator usb cable
Old May 16, 2007 | 10:30 AM
fearless06mcss's Avatar
Default predator usb cable
I got my predator a few weeks ago and i was wonerding if it comes with the usb cable or do I have to go out and buy one?
Old May 16, 2007 | 10:32 AM
06MonteSS's Avatar
LS1Tech Sponsor
you need a serial cable... you only need a serial-to-USB adapter cable if you don't have a serial port on your PC... but either way, it doesn't come with the power adapter or the serial cable... you have to purchase those separately.
You can either purchase the "PC Interface Kit" from a Diablosport dealer (part number U7777), or you can get them from Radio Shack...
Serial Cable:
Standard straight-through DB9 (9-pin to 9-pin) RS232C serial cable (6 foot cable is more than enough). Check your computer to see if you have a male or a female port on the back, as some are different. You will need a male end to go into your Predator.
(Radio Shack Part # 26-117, 6-ft DB9 male to DB9 female shielded cable.)
Power Adapter:
CLASS 2 TRANSFORMER
OUTPUT : 12VDC 1000mA (1 Amp)(Radio Shack Part # 273-1776)
Note: Plug Tip is 2.5mm x 5.5mm, female, and center is positive.
(Radio Shack Part # 273-1717)
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 16, 2007 | 10:43 AM
Thanks I will go after work
Old May 16, 2007 | 02:36 PM
BuffaloSS's Avatar
You got it a couple weeks ago and you're just NOW figuring it out? Geez...i wish i had that kind of restraint. lol
Good luck with it! You'll be happy.
Old May 16, 2007 | 03:42 PM
I guess I was afraid of changing the parameters without knowing what i was doing. Now that I've read up on it and somewhat understand it I am planning on doing some adjustments.
Old May 17, 2007 | 09:14 PM
06MonteSS's Avatar
LS1Tech Sponsor
here's some more reading material..
http://diablosport.com/index.php?nam...iewtopic&t=917
http://diablosport.com/index.php?nam...ewtopic&t=1145
__________________
