removing bowties/badges
Old Jul 26, 2007 | 11:16 PM
SSWS6's Avatar
Default removing bowties/badges
So I wanna remove my front/rear bowties, rear 'impala' lettering and the side 'GM' emblems. What holds them on? Adhesive? I assume all except the front bowtie I can just heat up with a hairdryer and pull them off. But what about the front bowtie? Please correct me if I am wrong.
Old Jul 27, 2007 | 12:02 AM
hexxLS4's Avatar
I love the debadged look. Only left the SS's on...in fact, replaced the small SS in the back with a larger side panel SS and went with another large one in the front grille...
I wouldn't just merely use a hair dryer...you run the risk of putting a ding or scratch on your paint.
Fishing line worked well for me....The badges are stuck on with a double sided 3M like tape. Just take some fishing line and saw as close to the emblem as you can untill all you're left with is adhesive in the shape of the emblem on your car. Then, in my experience, the adhesive peels right off. If you have trouble, doing it out in direct sunlight or heating the adhesive with a hair dryer is supposed to work well. Follow up with a little pin stripe remover (avail at walmart) if you need to...just dont use too much and leave it on too long.
The front bowtie badge is a little more tricky. The plastic grille underneath is in the shape of a bowtie. It has a little notch somewhere in the middle that goes into the back of the emblem to help hold it in place...Proceed with the fishing line technique. When you run into the notch, just start from the other sides until you're able to remove the badge.
Once you remove the badge and the adhesive, you'll have to find a way to cut the plastic notch...should be pretty easy....then sand it down. I went with a large SS badge in the front over the molded bowtie....looks great. I have pics if you want to see.
Good luck! You're gonna love the stealth look.
Old Jul 27, 2007 | 08:36 AM
Mark IXZD 150's Avatar
I'm not a fan of the new giant gold bowties so I removed mine too. I used dental floss to slice through the adhesive tape and then removed the residue with Goo Gone. Not an easy job though! That adhesive is unrelenting. You have to be careful on the front bowtie as the plastic grill is made of a soft plastic that can be easily scraped and can end up looking pretty ugly. I ended up having to sand (very fine paper) down the area under the old bowtie and then use a plastic polish on it to make it black and smooth again.
Old Jul 27, 2007 | 09:30 AM
eddiemoney's Avatar
I just let my car sit out in the sun and then used a hairdryer to give it a quick blast of extra heat. Then I used a body filler spreader to get under the emblems.
Old Jul 27, 2007 | 11:04 AM
npd4432's Avatar
I put vinyl over mine and pinstiped it red
Old Jul 27, 2007 | 12:50 PM
eddiemoney's Avatar
Old Jul 27, 2007 | 04:21 PM
Nacho SS's Avatar
I think the car looks great without the gold bowties and no logos except the SS .
Old Jul 27, 2007 | 08:17 PM
06MonteSS's Avatar
LS1Tech Sponsor
I just used a hair dryer on mine and pryed them off... came off pretty easy... just left the SS's on - put one on the front grill, and relocated the one on the trunk lid... see my PICS link in my sig...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jul 28, 2007 | 02:13 AM
SSWS6's Avatar
Thanks for the info and pics everyone. So when I remove the front bowtie do I need to put something there? Is there a big space there without the front bowtie? I may use an SS emblem but I would rather just have a blacked out grill.
Old Jul 28, 2007 | 08:55 AM
You'll have to put something there. There's a flat area the shape of a bowtie which would look odd IMO without something over it.
Old Jul 28, 2007 | 01:05 PM
hexxLS4's Avatar
Yes....put an SS there...gives it that "old school" touch.
Old Jul 29, 2007 | 07:55 PM
Taz34SS's Avatar
I cant wait to put the SS on the front. I am going to use floss to get between it and the black part and then use goo gone to clean up any areas that might need it. I think I will still leave the gold bowtie on the back.
Old Jul 29, 2007 | 07:59 PM
Nacho SS's Avatar
I would get rid of the one on the back....its HUUUGE!
Old Jul 29, 2007 | 08:03 PM
jabronie78's Avatar
Remove the Chevy symbol from the back and replace it with one from a Silverado. haha
Old Jul 30, 2007 | 09:37 AM
20SS07's Avatar
I'd recommend using fishing line instead of floss, only cause dpending on the floss it might tear easily. The fishing line went right through it no problem.
Old Jul 30, 2007 | 07:28 PM
Nacho SS's Avatar
X2
The floss breaks too easily. Plus fishing line is thinner and takes off some of the adhesive tape.
Old Jul 30, 2007 | 07:50 PM
Monte_Baby's Avatar
hi! where do you order the additional SS emblems?
Old Jul 30, 2007 | 07:58 PM
djfeezy's Avatar
E-bay or your local dealer
Old Jul 30, 2007 | 08:15 PM
Nacho SS's Avatar
AS much as i hate eGay, the dealer marks them up bigtime.
Old Jul 30, 2007 | 09:16 PM
20SS07's Avatar
I got mine off ebay. Guy I got mine from had pretty much any GM badge you would ever need. I got two SS badges for 30 bucks, dunno if that's a good price or not. I'm sure the dealer would have charged that for one. If you get an SS for the front grille, be sure to get the SS from the doors, and not the trunk, cause the trunk one isn't big enough for the grille.
