ls4 cam?
Old Aug 11, 2007 | 11:58 PM
someday's Avatar
if the DOD is in the lifters, y would changing the cam affect it? should still work no matter what cam was in there, as long as the lift was less than .590", right?
and the LS2 cam and heads r the same as the '01 LS6 cam and heads... so the LS4 heads r the same as those except with the old LS1 valve springs...
Old Aug 12, 2007 | 07:01 AM
06 SS's Avatar
The DoD cylinder lobes are different heights than the 'regular' ones. The lifters look to be different heights and that makes up for the difference.
Old Aug 12, 2007 | 11:12 AM
Notime383's Avatar
The crank is the only thing diff, Heads are 243 LS6 and any LSX cam should work! Don't get intimidated because it's sideways, it's mostly the same just tighter constraints! If GM doesn't come out with a nicer 4DR "SS" within the next 2-4yrs, I will pull this baby out, stroke it (383-408) and have the trans done by Eric@ DynoTech! Not a drag racer, just a 450HP cruiser that will go from 60-150mph with the best of 'em! Hmmm??? M5, E63, you get the picture! I'm kinda surprised we haven't seen that yet? Anyway's wish I had the ***** to put a cam in it now! 1400miles!I gotta wait!
Old Aug 12, 2007 | 04:49 PM
Nacho SS's Avatar
Too bad cam and tranny mods require the entire powertrain to be dropped.
Old Aug 12, 2007 | 07:15 PM
Notime383's Avatar
Most vehicles that your gonna modify cam/heads/trans will one way or the other require removal of the powertrain! This isn't too bad, it all comes down together then it's simple, those 4th gen f-bodies aren't much easier(valve springs)!
Old Aug 12, 2007 | 09:42 PM
Area47's Avatar
i guess no one paid attention when it was stated that the fast will not work on our engines with the dod.
please search, it has been asked, and answered many times before.
Old Aug 18, 2007 | 12:11 AM
jayklef5's Avatar
Originally Posted by crazboy99
be kinda cool to pull up next to a new monte or grand prix and hear it loping...like i said im just wondering
sorry to get stuck on a commment way back in the conversation but what is loping? i didn't realize there was a different sound that came with a new cam?
please help me
Old Aug 18, 2007 | 12:41 AM
Gregory's Avatar
Comp Cams makes camshafts for the 5.3 DoD engine. I know because I've called them. The only concern is the bolt pattern on front of the camshaft. The factory cam is likely the single bolt version whereas most cams made are still the three-bolt versions. Lingenfelter make an adapter for this.
Old Aug 18, 2007 | 01:40 PM
07MCSS's Avatar
We have the 243 heads from the Corvette LS6 motor and a similar intake.
Old Mar 10, 2010 | 01:17 AM
Purple94Z28's Avatar
So did anyone ever do this?
Old Mar 10, 2010 | 03:16 AM
blakss's Avatar
only Mix to my knowledge.. and i think..maybe the turbo GXP on Nitrous.. lmao. sorry cant think of this name.. lol
but yea think thats it..
Old Mar 10, 2010 | 07:04 AM
  #32
StealthV8's Avatar
people have done it with stock ls1 or ls6 cams i think. but noone has done an aggressive one yet.
Old Mar 10, 2010 | 01:14 PM
  #33
Nacho SS's Avatar
The most aggressive cam so far is a TR224 IIRC.
Old Mar 11, 2010 | 01:35 AM
  #34
blakss's Avatar
yea think thats what mix gots.. not sure.. but doesnt thunder racing use less lift with a fast ramp rate? think thats key ,,less lift due to the lifter with DOD..?
Old Apr 29, 2011 | 12:01 PM
  #35
my08impalass's Avatar
I kno there's a guy on YouTube that used the tr 224. SOunds good. His is an 07 impala SS.
Old Apr 29, 2011 | 01:03 PM
  #36
707chance's Avatar
Default cam
I know of one DOD cam swap and 4 nonDOD cam swaps. My cam is a 056 Boss; http://www.vincihiperformance.com/CA...%20LS1%202.htm not alot of lope but I'm setting my car up for N20. Be forwarned a cam swap has alot of hidden costs.
Old Apr 29, 2011 | 04:53 PM
  #37
LS4:20's Avatar
Youtube: Type "Sound Off GXP Mustang", first video, kinda dark, both cars *** ends.. That's a cammed LS4, using the New Era G8GT High Lift DoD cam.. I don't see why aftermarket cams for the LS1/2/6 won't all fit?
Old Apr 29, 2011 | 07:13 PM
  #38
94ss06gxp's Avatar
http://www.youtube.com/watch?v=is5SXiEA6i4
Old Apr 29, 2011 | 10:20 PM
  #39
Mels SS's Avatar
A lot of good info makes me wounder
