ls4 cam?
Well FWIW, couldn't you just switch out the lifters to Ls2 spec ones? And what is stopping us from installing a Fast 90/90?
it's the cam.
you can swap the lifters out, pull all the dod crap off, shut the codes off with hpt. and have fun.
with short crank snout, the ls4 and ls6 block are 2 diff. castings.
ls4 is based on 4.8/5.3 iron block but cast in alloy with pressed in sleeves
