Removed your hood insulation???
Is there a reason we're concerned about the underhood insulation? Are we thinking it has some effect on the underhood temps in a negative way?
I'm just concerned with all the engine heat these things put out cookin' the paint on the hood and screwin' something up...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
I’ll have to get the under hood temp really hot and use a temp gun to measure the heat at the rear of the hood before and after removing the strip everyone is talking about. I doubt I will remove the insulation from the underside of the hood.
I wonder and am not sure any one mentioned the insulation and strip at the rear could also reduce the air flow in the event of an engine fire. I would think if you opened up the flow by removing the rear strip you would create a fresh air feed to the fire.
Don't put down other member's rides.
didn't mean to sound like I put it down... just meant to say I didn't think it ran as hot as ours... I know this is the hottest running car I've ever owned...
Never seen an inferno hood before...
http://www.pfyc.com/pc/GP1901/04/Gra...+Air+Hood.html
