GXP Performance Parts
Old Sep 12, 2007 | 08:07 AM
Taz34SS's Avatar
yes, it is the JBW intake.
Just get the K&N and you will be all set
Old Sep 12, 2007 | 08:26 AM
alex94z's Avatar
Wouldn't a fender-well intake have an advantage over the K&N because it blocks off heat from the engine bay?
Old Sep 12, 2007 | 08:33 AM
Taz34SS's Avatar
Well, since alot of the guys on here have used the K&N and also there are 2 of us, myself and HExx tested both the CAI and the K&N, and found the K&N to be better performing then the other. I would just stick with something that is proven.
Old Sep 12, 2007 | 08:38 AM
hexxLS4's Avatar
True. I think it's only due to the better piping on the K&N. If I knew then what I know now, I would have kept the CAI and fabbed up better tubing. That would have been the best of both worlds. To be honest, I'm curious about this FWI...but I'm def not about to drop money on it. The K&N does a great job so far.
Old Sep 12, 2007 | 09:10 AM
Taz34SS's Avatar
Ive been wondering about that aswell. Maybe CAI will come out with a better tubing system then just using stock with there CAI. Then, maybe it would be a better system.
Old Sep 12, 2007 | 10:11 AM
hexxLS4's Avatar
I emailed the owner but no reply. I don't think he cares.
Old Sep 12, 2007 | 10:14 AM
Taz34SS's Avatar
Well, I dont know about that. When I have called him before, ( when I owned the CAI ) he was really great and wanted to take care of me in any way he could. He has a normal job and makes the CAI's on the side. I will try and talk to him this week and get back to you.
Old Sep 12, 2007 | 10:25 AM
hexxLS4's Avatar
I'm sure he's a nice guy, but he's failed to respond to a few of my emails. It's not a big deal though. You don't have to talk to him for me. I was just trying to help him make a better product. It makes no difference to me at this point.
Old Sep 12, 2007 | 12:35 PM
06MonteSS's Avatar
LS1Tech Sponsor
I'd like to know if he's gonna make an intake tube to go with his CAI box... that would be killer....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Sep 12, 2007 | 01:10 PM
hexxLS4's Avatar
You gave me a link to this site a while ago: http://www.spectreperformance.com/modularintake/ Why don't you just craft one and make a sticky for everyone?
Old Sep 12, 2007 | 01:23 PM
06MonteSS's Avatar
LS1Tech Sponsor
yeah, forgot about that link...
can't make stickies (yet)... haven't gotten any info as to what's goin on with the Mod position...
last I heard was that post that Richie made, about if it all goes quick - I'd be a mod by the end of the day... and that was it, last I heard about anything...
__________________
Old Sep 12, 2007 | 01:40 PM
  #32
hexxLS4's Avatar
fab one up while you wait! You should have sticky power by the time it's done.
Old Sep 12, 2007 | 01:41 PM
  #33
DavidGXP's Avatar
Does adding an intake require recalibrating the mass air flow sensor? 05 and up Fords
don't see any real power gains from intakes unless the MAFS gets reworked. I guess their real sensitive!
I don't think that our box is all that restrictive. The only problem that I see is the small *** tube that is used to suck in the air attached to the box. Many people have taken it out, but I think it helps to speed up the incoming air and properly direct it. I would like to cut the front of the box out and see what happens and change the filter. I'm just waiting for a high flow oil less air filter to come out for our cars.
What if we were to use ceramic coated pipe for the intake tubes and the stock box
with a high flow filter? Also, I was thinking about running a pipe through the side of the box that comes from the fender and goes down to the front bumper. The pipe would have to be angled inside of the box of course. I'm even thinking about fiberglassing the
inside of the box to cover up the ECU and to add some direction baffles. These cars were supper engineered from the factory so I like to question every mod. Always think Super stock. Those cars hauled *** with stock parts back in the day!
Old Sep 12, 2007 | 02:01 PM
  #34
hexxLS4's Avatar
Originally Posted by DavidGXP
Does adding an intake require recalibrating the mass air flow sensor?05 and up Fords don't see any real power gains from intakes unless the MAFS gets reworked. I guess their real sensitive!
Not really, plug it in and you will see instant gains. Over time, the computer will compensate and adjust to the new air intake...most people just unplug the power from the battery for 20 mins or so to reboot the computer. Someone on here also mentioned you can pull a certain fuse if you don't want to wait.
Trust me, there is plenty of power to be gained by replacing the stock box. K&N claims 13.x HP to the wheels according to their dyno.
I've seen people speak against this. Supposedly the tube is used to help make the incoming airflow more uniform. Taking it out might cause turbulence and perhaps result in less power? Shrug.
What if we were to use ceramic coated pipe for the intake tubes and the stock box with a high flow filter?
That tubing is definately restrictive. If you decide to stay with the stock box, you'll definitely want to replace it.
Super engineered? heh...no comment. I guarantee that you will be very happy with the performance from an intake in these cars. I know I am. There is definitely plenty of restriction in the stock box setup. But by all means, see what you can do with the stock box! I'd be interested to see how it goes.
Old Sep 12, 2007 | 08:26 PM
  #35
LSX Performance's Avatar
Kinda off topic now. Does anyone know if there are lowering springs for the GXP?
Old Sep 12, 2007 | 08:35 PM
  #36
Nacho SS's Avatar
There's an eibach kit....search on here for it...like a 100 threads on it lol.
Old Sep 12, 2007 | 10:19 PM
  #37
06MonteSS's Avatar
LS1Tech Sponsor
FORD's are REAL sensitive to ANY airflow changes...
__________________
Old Sep 13, 2007 | 06:28 AM
  #38
Compg's Avatar
As far as Intakes go, most all people will tell you that a well made FWI will perform just as well or better (colder air) as a CAI for a lot less money. People have dynoed over the years and different companies will tell you that a FWI does work and can be made for cheap. Now does a CAI like the K&N look better, YES without a doubt but that's all up to personal taste. The key to FWIs is to make the piping as short and straight as possible (resulting in less restriction) while keeping the filter of the intake out of the engine bay (resulting in colder air temps).
Tate
