This is odd?
Old Sep 18, 2007 | 09:56 PM
SS_Black_Attack's Avatar
Default This is odd?
My car resets itself. Let me explain. I set up my EQ on the radio and occassionally it clears itself to flatline. That's odd... Once in a while, my compass clears itself, no reason. That's odd... Once in a while, I go to start my car and the starter cranks and cranks, then I turn the key off and back on and it starts instantly. That's odd...
Does anyone else have these occassional odd things happen to them, and is this an early warning sign of a computer problem???
Old Sep 18, 2007 | 10:11 PM
Sint3k's Avatar
My radio does do weird things. For instance it will randomly start at the beginning of the CD. But nothing to the extent you are talking about. I've never had a cranking problem. One turn over and its started. When you turn your key you should easily hear the fuel pump turn on i would listen for it just to knock that out.
Old Sep 18, 2007 | 10:36 PM
Corny40's Avatar
Don't know about your other issues, but the radio thing, I may be able to add some insight to. For every "input" on your radio (AM/FM, disc, aux), you can have a different EQ setting. For example, if you're listening to a CD and set the EQ to certain parameters, then decide to switch over to your mp3 player, the EQ setting will not follow, (unless you've already set it to the same parameters).
Does that make sense?
Old Sep 18, 2007 | 10:58 PM
Sint3k's Avatar
I never noticed that i always leave my EQ flat anyways so i would never notice a change in the EQ.
Old Sep 19, 2007 | 12:27 AM
Nacho SS's Avatar
Yeah I get that same thing sometimes. For example, the passenger seatbelt light won't go off, and I get a message in the DIC that says check seatbelt system. Or sometimes it doesn't even recognize when there's no passenger there lol....
this car has more bugs than a beehive!
Old Sep 19, 2007 | 11:59 AM
BuffaloSS's Avatar
SS Black...sounds like your battery connection is failing you...or the internal memory is going bad.
Whenever you pull the neg cable to the battery, the items that need to eventually be reset are the clock, the radio EQ and other settings (Speed Comp. Volume, # preset pages) and the compass.
Old Sep 19, 2007 | 01:27 PM
a612662's Avatar
Nacho SS, I had the same kind of issues, the dealer had to reprogram the bus or something. Once the new program was in the problem hasn't come back.
Old Sep 19, 2007 | 04:18 PM
Taz34SS's Avatar
I have had the compass reset itself maybe twice since ive own the car, but the rest of the stuff, like the MPG, avg. speed, oil life all stay the same.
Maybe my car have a bug in it?
Old Sep 19, 2007 | 04:20 PM
Taz34SS's Avatar
Sounds like your Alt. is wearing down and your battery is not holding a charge.
Very common for the Chevy's to go through Alt and Battery problems together at once.
Old Sep 19, 2007 | 08:06 PM
Nacho SS's Avatar
Thanks for the help...and if you're new here (judging by your post count) welcome!
Unfortunately, the car just came back from the dealer after I complained about 5-6 problems that they hopefully fixed. I'll put it on my list for next time!
Old Sep 19, 2007 | 09:30 PM
Sint3k's Avatar
I had the same problem they updated the BCM
Old Sep 20, 2007 | 02:40 PM
Kazmaniac's Avatar
No comments on electrical problems because I'm not going to jinks mine.
But ... my GMC Safari AWD tow vehicle would do a self - cal / reset at least once a month on the DIC.
Different manufactures; generations of hardware and software between the two.
Mine went in last month for a TPMS issue, walked away with that nice new module that works from 200 yards away, and had the entire car reflashed to Sept '07 software.
Old Sep 20, 2007 | 08:15 PM
Nacho SS's Avatar
I got that fixed too....very nice. I find the electronics don't hum as much anymore.
Old Sep 20, 2007 | 08:23 PM
BuffaloSS's Avatar
I just keep adding stuff to my list for the dealer. Each time i log in someone reminds me about a problem i have forgotten about. Therefore, each time i log in i effectively need to add two days to the amount of time the car will be at the dealer.
Old Sep 20, 2007 | 10:48 PM
Kazmaniac's Avatar
Buff, you are by far the most dedicated car owner I have known!!!
I would have gave up long before!
Old Sep 21, 2007 | 12:19 AM
Nacho SS's Avatar
If I were Buff, I would look at driving a panzer tiger II.
Old Sep 21, 2007 | 01:42 PM
Sint3k's Avatar
Do what i do i make a list and throw it at them because theres so much **** i keep forgetting something. Now my drivers power seat is messing up. The front part of the seat wont raise or lower but i hear the motor trying. Also i have alot of popping in the steering for some reason now. I don't want to take it in cause i don't want them making it worse or telling me "we can't duplicate the problem"
Old Sep 21, 2007 | 01:51 PM
06MonteSS's Avatar
LS1Tech Sponsor
my steering has been making the "popping" noise for a while... first they replaced the Intermediate Steering Shaft (yes replaced, not just lubed), that didn't fix it... so now they have a new steering rack ordered...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Sep 21, 2007 | 06:52 PM
Nacho SS's Avatar
^great....something I have to add to the list.
Old Sep 22, 2007 | 03:30 AM
Sint3k's Avatar
I just wish the challenger or camaro would come out so i can trade in the MCSS its a great car but its got me wanting more power , more everything. 06MCSS shoulda been a ls2 /w rwd
