sunroof stuck open
Old Dec 6, 2007 | 05:21 PM
06 SS's Avatar
Default sunroof stuck open-resolved
dang thing will close to the vent position, but then locks up, won't go fully down. Of course the car is outside and we are expecting 6 more inches of snow. Lousy garbage bag is not going to keep the wet out. Is there any way to crank it down by hand? Owners manual is completely useless on anything but which button is supposed to close it. Can open and close it (it stops 3 inches on the way back until I hit the button again and then goes until it hits some sort of limiter and the lights dim from the current draw, so it is not right)
Old Dec 6, 2007 | 05:30 PM
06MonteSS's Avatar
LS1Tech Sponsor
did you check the rails?? nothing bent or blocking them??
as it's closing, have someone on the outside try helping/pushing it to see if it gets past the stuck point and closes down.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Dec 6, 2007 | 06:22 PM
06 SS's Avatar
nothing on the rails, tried 'helping' it. It is like it jumped over some travel limiter and doesn't know it is closed and ready to pull it down.
Old Dec 6, 2007 | 06:23 PM
cherrygxp's Avatar
x2 if check the rails for ice or anything. And if your expecting snow it must be cold so why was it opened lol
Old Dec 6, 2007 | 06:34 PM
06 SS's Avatar
crisp day, smooth tobacco, new pipe, sunroof open for smoke. Rails are clear and greased properly.
Old Dec 6, 2007 | 07:15 PM
06MonteSS's Avatar
LS1Tech Sponsor
just for ha-ha's... try disconnecting the battery for about 20 minutes... see if that clears any glitches that may have occurred in a module somewhere...
__________________
Old Dec 7, 2007 | 06:30 AM
cherrygxp's Avatar
Any luck or are you shoveling out the snow?
Old Dec 7, 2007 | 06:47 AM
06 SS's Avatar
gave up, covered it up, waiting for it to get light, then calling the dealer. Hopefully not going to have to take a shovel to the interior. Only got about 2 inches, so we shall see how much got in.
update, no snow inside (except when I pulled the plastic off and tried one last time to open/close it, so a little now). Now it is stuck open even further. Leaving for dealer in about 30.
Old Dec 7, 2007 | 01:29 PM
06 SS's Avatar
Ok, all fixed. Dealer claims two bad grounds caused a module to forget its programming. Got the tires rotated as long as I had it in and griped about the squeeling window when it gets warm. They further claim that one is not the window seal in the TSB, but the entire internal mechanism, so they are ordering that. We shall see.
Old Dec 8, 2007 | 06:13 AM
06 SS's Avatar
Ok, it's on now!
Opened up my guaran-goddamn-teed sunroof on the way back from work this morning and it, of course, is stuck open again. Same symptoms as before. It seems the service guy is going to have an exceedingly unpleasant morning.
Old Dec 8, 2007 | 09:32 AM
06impSS's Avatar
Wouldn't be too bad if you lived here, but up there, brrrr.
Old Dec 8, 2007 | 11:09 AM
cherrygxp's Avatar
wow thats BS. Let us know how ya make out
Old Dec 8, 2007 | 12:51 PM
06 SS's Avatar
They got it closed and are ordering an entire new assembly, which tells me they have no clue. Probably burn that one out shorty after it gets installed.
Old Dec 8, 2007 | 01:39 PM
Nacho SS's Avatar
Forget the dealership, just get on top of the car and sit on the sunroof for it to close...
