HELP! With stock tune and diablosport!
maybe try reloading a diablo tune.. start the car... turn it off... and restore the original backup again...
also, you can pull the ECM/TCM fuse for a couple minutes to reset all the learned parameters... this should clear anything up...
the fuse is in the fuse block under the hood... it's a blue 10 amp fuse under the STRTR relay in the upper right... the owner's manual tells/shows ya where it is...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
as long as the stock tune got back in there, you're fine... probably didn't run it long enough for stuff to get relearned, like the idle, trims, etc etc... no biggie..
https://ls1tech.com/forums/showthrea...ghlight=diablo
Anyways, the tow truck guy showed up and she started up fine. I was able to drive her up the truck with no problems (this is with the stock tune back in). Hopefully, there will be no problems when it gets to the dealership. Otherwise, I'm just gonna play dumb and they'll probably just reflash it over there or something.
Either way, it left here with the stock tune. So I feel better now. Thanks for the help!
