Resonator?
Old Jan 5, 2008 | 04:49 PM
Count of Monte Carlo's Avatar
Default Resonator?
How long is the resonator? And what is the inlet and outlet pipe width? ThankZZZZZZZZ!!!!
Old Jan 5, 2008 | 04:54 PM
Sint3k's Avatar
inlet/outlet is 2.5inch and its length is around 18 inch's or so
Old Jan 5, 2008 | 05:00 PM
Thank you Castrol SynTech!!!!!
Old Jan 5, 2008 | 05:16 PM
Sint3k's Avatar
Actually this was my hacker name , it meant Sinister Technology you can google my name and see some of my work.
Old Jan 5, 2008 | 06:11 PM
Taz34SS's Avatar
Contact Kurt @ hogan performance. He made me a custom 1 off res removal pipe and it fit like a glove.
Old Jan 5, 2008 | 08:10 PM
do you know how much that ran you??he include any hardware?
Old Jan 5, 2008 | 08:28 PM
Taz34SS's Avatar
Again, contact Kurt. He is a great guy and has great customer service.
Old Jan 6, 2008 | 05:53 PM
cherrygxp's Avatar
does just removing the resonator make it any louder?
Old Jan 6, 2008 | 06:09 PM
Taz34SS's Avatar
Yes. A Resonator is just like having a 3rd muffler on your car. Remove it with a straight pipe and it will sound alittle better.
Old Jan 6, 2008 | 08:02 PM
Nacho SS's Avatar
If you want some wicked sound, either put bullets in place of your stock mufflers and place a glasspack where your res is (Old-School muscle sound) or run a bullet for the res and no rear muffs....it'll roar!
Old Jan 6, 2008 | 08:30 PM
cherrygxp's Avatar
thanks guys. Im just bored and its supposed to be nice out the next few days so im gonna try the res removal. Not sure if i want to go with magnaflow or something custom so im waiting till spring for full exhaust.
Old Jan 6, 2008 | 10:49 PM
Taz34SS's Avatar
If I had to do everything all over again, I would get the sizes and just do a custom 3" exhaust with Hogan. I would give him all the sizes starting with the cat/back flange and work my way back.
But the cheapest thing would be ordering the Magnaflow system and also ordering the res removal pipe from Hogan.
Old Jan 7, 2008 | 09:31 AM
EmersonHart13's Avatar
40 bucks to cut mine out and weld in a pipe.
Old Jan 7, 2008 | 11:45 PM
Taz34SS's Avatar
304, 409 or alumium steel?
Old Jan 8, 2008 | 05:15 AM
Sint3k's Avatar
IF i did it all over again i would keep the stock mufflers and just put a cutout on it. Instead of a cutout and flowmasters
Old Jan 9, 2008 | 07:28 PM
mikeroot2's Avatar
Had my resonator removed took it for a test drive. Barely louder at all. Went back had them install two bullet mufflers. I think it sounds good. Too raspy without res or muffs. I'll try to get an audio clip posted. cost me $110 total. not stainless, but nothing else under there is either. Had them reinstall the factory tips. looks stock. sounds mean.
Old Jan 9, 2008 | 11:21 PM
What would be louder? Resonator removal or 3inch down pipe with catalyst?
Old Jan 10, 2008 | 12:37 AM
Corny40's Avatar
I may be wrong, but I always thought that the sole purpose of the resonator was to reduce interior noise, not to really change the exterior volume.
Old Jan 10, 2008 | 01:55 AM
Taz34SS's Avatar
OEM Exhaust pipes from GM are made of Stainless Steel on the SS. The Mufflers are are not. Thats why they will rust out faster then the pipes will.
As for what would be loud, go with a larger downpipe with no cat and straight exhaust with no mufflers would be the loudest.
Now if you want to be somewhat legal, go with a larger downpipe with a high flow cat, then straight exhaust, no res into a GOOD set of mufflers.
Old Jan 10, 2008 | 07:51 AM
Catalyst stays... NY will not pass me without it. AllI know is that the GM cat Is rather large....From my experiance it absorbs sound.. the Muffler I have now, oddly enough make engine sound like stock only louder, it's a free flow design.... But I want to the car to be as loud as my Pontiac...which has the same mufflers and an aftermarket catalyst. It is loud enough to know when I'm coming and going, with being civil at cruise and not rattling my fillings out. Now that you said the stock mufflers arent stainless I feel even better about removing them....I'm pretty confident the Aero Chambers will absorb all the raspyness as it has done on my GP....my stainless pipe should be here today....
