Tpms
Old Jan 26, 2008 | 09:09 AM
SSWS6's Avatar
Default Tpms
So I never used my TPMS when I had my 22s, but now I'm back to the stock wheels/tires so I want to hook it back up. How do I do this and what parts are needed? Do all the wheels need to be dismounted from the tires? Will the dealer rape me to do this? I never had TPMS before so I'm pretty clueless. One thing I don't want to have to do is reflash the PCM. Resetting it should be ok though, as my tune should still be there.
Old Jan 26, 2008 | 10:58 AM
mike690003's Avatar
The dealer has a special hand held unit that automatically resets the TPMS sensors. If you are still under warranty, take it in and tell them the TPMS system is not working correctly. Then you will get it recalibrated for free. The process takes less than 5 minutes.
Old Jan 27, 2008 | 12:32 AM
Corny40's Avatar
So, did you leave the TPMS sensors in the stock wheels? If so, you just need to do the re-learn procedure. It's very easy. Just tell the DIC that you're going to do this, then it's just a matter of adding or releasing air from the tires, so the car car learn their positions (start with the LF and go clockwise). The owner's manual explains the process in detail.
If you did leave them in the stock wheels, there's a chance they went bad. There was a guy on naioa.com that had his go bad while they were just sitting in storage.
Old Jan 27, 2008 | 05:58 AM
SSWS6's Avatar
Not sure if the sensors are still in the wheels but they should be. First I'll try to do the re-learn then if that doesn't work I will just go to the dealer. Thanks guys.
Old Jan 27, 2008 | 11:14 PM
BuffaloSS's Avatar
Unless you took them out, they're still in there. Just do as Corny said...pretty easy. If you can't get the computer to relearn one or more, your best bet is to buy them online and have a tire shop install them....should cost the same as a new valve stem install if you provide the new sensor(s).
Old Jan 28, 2008 | 07:39 PM
Kazmaniac's Avatar
All 4 of mine have failed now.
Those sensors go bad because of very crappy / BS'd validation or more than likely in this case out of spec production issues from a "low cost supplier" on a $30K vehicle.
Get in car, start, clear TPMS warning message / all warning messages, drive.
Are the e-bay solutions non-OEM? No way I'm paying $80 + install to do this over in 20K.
Old Jan 28, 2008 | 09:38 PM
BuffaloSS's Avatar
Nope...nothing aftermarket yet...unless you want to buy the complete aftermarket kit from Tirerack or something. it comes with its own receiver but only tells you when a tire is low. IMO, stick with OEM or turn the entire system off.
Old Jan 28, 2008 | 11:15 PM
staringback05's Avatar
tpms is garbage...seriously any real person driving there car should give more then two ***** to check there tires and not be lazy...those sensors are off half the time anyway, and the dealers rape people on them...there a bitch to tire techs when they have to dismount and mount tires...and you have to have a special device to reset them
Old Jan 28, 2008 | 11:41 PM
Nacho SS's Avatar
Quoted for truth.....
Old Jan 29, 2008 | 01:00 AM
Kazmaniac's Avatar
I'm all for technology when it WORKS, #1 pick is ABS / traction control. Mine never "works" because I know how to brake on dry / wet, but in the snow nothing stops / accelerates. Satellite radio - good!
I used to use the TPMS to monitor the tires when they heat up, mine were very close in accuracy. I have a TPMS mirror for my Z28SS, but never installed it because I'd lose the only interior lights in the mirror.
BTW - these are not the "tool" reset ones (which were rare earth magnets, IIRC)
Old Jan 29, 2008 | 09:38 AM
pic of them?...
only ones ive delt with is a belt device around the rim...which takes a little red box...
and the one thats actually connected to the valve stem...which takes the box to..
Old Jan 29, 2008 | 10:14 AM
BuffaloSS's Avatar
You can still use the magnet to reset them...but you don't need to. However, it would help so that you're not letting out half the tire's air, or putting that much in and having to release it all over again to get back in to spec.
B/C i didn't know you could eliminate the system altogether, I bought a new set of sensors for my spring/summer/fall wheels. Won't know if they work 'til I get the set installed in a couple months.
Old Jan 30, 2008 | 01:21 AM
Kazmaniac's Avatar
Let me find the box in my garage and I'll try to get a pic for you.
Old Jan 30, 2008 | 03:56 AM
deft's Avatar
how can you eliminate the system altogether---other than not worrying about it and clearing the error message. also....anyone have any pictures of our sensors---im curious what they look like.
Old Jan 31, 2008 | 12:20 AM
Corny40's Avatar
Here you go.
http://cgi.ebay.com/ebaymotors/06-07...spagenameZWDVW
I believe the TPMS monitoring can be eliminated from the ECM at the dealer.
Old Jan 31, 2008 | 10:09 AM
BuffaloSS's Avatar
Yeah, the dealer can do it. If they tell you they can't, it's BS. I know guys at NAIOA that have had it done.
