What is wrong with this and how does this happen??
So as u can see on the
inside of the tire its worn so bad. the tires have about 20kmi and the fronts dont look near as bad. Is the rear end out of alingment??? ima take the car in next week for iss and ima have them look at this also. i just cant believe how an 07 w/ 20kmi looks that bad on the rear tires.
If there is a problem can i get the deal to replace the rear tires or am i **** out of luck?
also ive never had a car new enough to have a warranty, and the other day someone wrote that the dealer gave them a rental car. Is this common or am i walkinng home most likely???
new tires this year will be the goodyear eagle F1 all-seasons....
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
You can not rotate the gxp wheels....the fronts are different than the rears.
PM sent about signature kylegxp
Anyway, your alignment is way off, and you should have been keeping an eye on this, so they'll likely tell you you're SOL. If you caught the poor alignment before 10k, they may have fixed it for you, but now it's on you, i'd say.
Yep we have larger tires/rims up front than the rear!
Hey Kyle, how do you like those RE050As???
GXPs.....
Don't be a hater. J/K.
