just got the eibach springs installed
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Oh, if anyone's wondering, BFH = Big ******* Hammer.
Sorry, but how do you figure? If there isn't an adjustment from the factory for camber, how do you expect anyone to be able to make adjustments without a kit? With a BFH?
That's the whole point of a camber bolt kit. It gives you the ability to adjust where you didn't have the ability before.
heres a link to the pics http://s274.photobucket.com/albums/j...on=tageditmany
http://s274.photobucket.com/albums/jj280/turbosupra95/
EDIT:
I love the drop in the front...unsure of the back. Now I gotta find some money to buy dj's kit.
This appears stock:
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar021.jpg)
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar020.jpg)
Then lowered...?
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar022.jpg)
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar023.jpg)
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar027.jpg)
![](http://i274.photobucket.com/albums/jj280/turbosupra95/mycar024.jpg)
FWIW, my car sits lower in the rear STOCK than yours does lowered...unless you only put the front in (too lazy to look back at your original posts). Your presumed stock photo looks like the rear was jacked UP from the factory...can't remember my car ever sitting that high back there. Gonna dig up a stock photo (from 2.5 years ago).
![](http://i33.photobucket.com/albums/d94/BuffaloSS/IMG_0104.jpg)
yea thats what i was thinking too the rear sat like unusually high i thought and after i put the kit in i thought it would get rid of most of it but it didnt really and after driving with the springs for a few days the ride quality is horrible every bump u feel and i tried testing the springs out just before on my road cuz its got some nice windy corners and i took one at 40 and i felt the tires rubbing the wheel well so all in all i think it was a waste of almost 600$(kit+install) that i could have used on say a tune or the nitrous
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Does look a little high in the rear. Give it a few weeks to settle.
Got mine installed today. Cost me $280 for install with a 4 wheel alignment. Overall I'm happy with the look so far and I personally like it just a bit higher in the back, but not too much. And if its too high for me in the back once they settle I will just throw some subs or weights or something in the trunk. Heres a pic below but it was kinda dark when I got home so I'll try to post better pics tomorrow.
![](http://img.photobucket.com/albums/v619/chammel/impalalowered.jpg?t=1203993974)
Honestly, the car doesn't really look lower than stock in the picture, but it looks a lot better in person.
The rear on mine looked just like yours when I first installed the Eibach's. Honestly, it took about 2 months for the rear to "settle". I can only assume it's because it's so light in the rear, as compared to the front.
Anywho, you'll be real happy as soon as they settle.
ImpalaSS07, forgive me for asking this but are you sure they installed the rear springs? The only reason I'm asking is because in the 4th picture Buffalo posted the rear doesn't look any lower than stock. And mine definetly does look lower than stock in the rear, and I just installed mine yesterday. Everyone's car is different so hopefully its just like that and it will eventually settle, but the difference between the front and rear seems a little much. Also, my ride quality wasn't affected at all. And I haven't tried to take a turn at speed, but I don't feel the bumps any more than before.
#38
I'm a little late to this thread. I'm also considering the Eibach ProKit, but not sure I want to spend the money. I was looking at the pics and I'm kinda curious. Are the front and rear springs identical? Looks might be but the compression may not be? If that is the case, is it possible they installed the rear on the front and vice versa? Main reason I ask is that in your first pics of the before and after the front looks like it lowered almoste 2 inches, and the kit is only advertised for about 1.3. Then your rear is almost higher than stock. With the weight's being different for the front and rear of the car, it's possible the springs are swapped.
My 2 cents for what little I know about suspension.
